Boston Acoustics Pro60
Old Sep 9, 2005 | 08:53 AM
anubyss's Avatar
anubyss
Default Boston Acoustics Pro60
Does anyone have the Boston Acoustics Pro60? I am wondering about the spacer needed for this unit (more than 1"?). I am doing the install soon and would like to have everything ready so I don't waste time running out to Home Depot or audio shops. Thanks.
Old Sep 9, 2005 | 09:34 AM
THEDUKE's Avatar
THEDUKE
You only need a 3/4 inch spacer. I am running the Z series speakers from Boston and only used 3/4 inch spacers. I also recommend using the axis mounts, do not use the factory tweeter location. It will sound to harsh and bright. The factory tweeter location sucks.
Old Sep 9, 2005 | 09:45 AM
anubyss's Avatar
anubyss
Thanks. I guess I can just buy a standard kit then. I didn't really want make one out of mdf. I think I am set with my system now.
Old Sep 9, 2005 | 02:27 PM
orangeboy's Avatar
orangeboy
I'm using the BA 6.5 pro's, exact same mounting dimentions as the newer Pro60's though.
Laminated two pieces of 12mm MDF together for the spacer ring & stuck it on top of the Dynamat. This is just thick enough for the glass to clear the magnet.
Old Sep 9, 2005 | 07:16 PM
anubyss's Avatar
anubyss
I figure I would just get the Metra 1" spacer from Circuit City and trim it down if need be. Thanks for the post.
Old Sep 12, 2005 | 04:07 AM
LS350Z's Avatar
LS350Z
Charter Member #56
It's important to note that even though Boston Pro60s, Reference Z6s, & old Pro 6.5s all have a 63mm mounting depth - the new Pro60s 3/4" spacers so I'm sure the Pro60s will work no problem. I'm now spacered 1.5" and centered in the door cutout which is even better.
Old Sep 12, 2005 | 05:34 AM
anubyss's Avatar
anubyss
I bought the Metra 1" spacer but ended up cutting the stock speaker out of the cradle and using it instead.
Anyone2u
Dec 9, 2003 06:46 AM
jeffrey
Apr 12, 2003 08:29 PM
DBTRACK
Jan 3, 2003 10:01 PM
Anyone2u
Audio Builds
Dec 3, 2002 03:09 PM
Miami350Z
Nov 26, 2002 12:24 PM
