Speaker Question
Old Sep 11, 2005 | 03:07 PM
skip2daZ's Avatar
skip2daZ
Default Speaker Question
First of all, I have two infinity subs(10.1D) and a 611a amp comming in this monday, oh and also i already got some alpine speakers for the rear.
My question is this, i am planning on putting in the polk mmc6500 components in the front but i have no intention of getting an amp for them at this time, so can i run those component of the headunits amp?
These are the specifications for the speakers:
Overall Frequency Response 43Hz - 25kHz
Nominal Impedance 4 ohms
Power Handling (continuous) 125 w
Power Handling (peak) 250 w
Efficiency 90 dB
Crossover 2.6kHz 2nd order High & Low Pass
Crossover Dimensions 6" x 3-5/8" x 1-1/2"
(15.24cm x 9.21cm x 3.81cm)
Voice Coil Diameter: Driver 1" (2.54cm)
Voice Coil Diameter: Tweeter 1" (2.54cm)
thanks
Old Sep 11, 2005 | 03:21 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Sure why not?
Your subwoofers can be driven from the RCA connectors to the amplifier and then into the drivers. The headend can directly feed the components. Eventually if you want to run the four 6.5" speakers with an amplifier you'll need to run the RCA cables for those, install a second amplifier, and then run new speaker wires from the new amp to the speakers.
Old Sep 11, 2005 | 03:27 PM
skip2daZ's Avatar
skip2daZ
oh nice... thanks for the quick response paul
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
