Simple harness question
Old Sep 18, 2005 | 04:26 PM
Joshness's Avatar
Joshness
Default Simple harness question
I read through alot of threads and couldnt find a simple answer... But...
I Have an 04 Touring Coupe, with BOSE, non-navi
I want to only replace the headunit, but people have told me that I either have to re-wire the whole car, or disconnect all kinds of bose stuff and whatnot... I just would like to know if anyone makes a Harness out there that I can do a simple plug-and-play keeping all the speakers, and only changing the head unit.
Thanks
Old Sep 18, 2005 | 05:47 PM
SungNamZ's Avatar
SungNamZ
Ditto! Head Unit has been repaired/replaced three times and not looking forwarth to the 4th.
Old Sep 18, 2005 | 07:29 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Crutchfield sells a pair of cables that will plug-n-play once you get them soldiered into the side for your aftermarket radio. You also have to plug in the antenna cable and I recommend running a nice sized ground wire from the back of the after market radio to the big dash ground point just behind the combination meter in the triple dash cluster.
Nissan Receiver Wire Harness For select models, 1995-up
Item #120707550 - is the model they sold me for $13 to match my Bose system. Double check to make sure that it matches the non-Bose system too. Crutchfield has a "what fits my car" walk through to sort the cable automatically.
Old Sep 18, 2005 | 08:29 PM
Joshness's Avatar
Joshness
That part number shows up on crutchfields site no matter if you select with or without bose... so whats the difference if I just go to best buy and buy thier standard harness, because according to crutchfield its all the same part?
Old Sep 20, 2005 | 09:36 AM
jcastino's Avatar
jcastino
By chance, is the Bose unit you are taking out the satelite reciever? If so, I would be interested in it!
Old Sep 20, 2005 | 02:47 PM
Joshness's Avatar
Joshness
Sorry, its just the 6Disc/radio/cassete deck.
Not to mention the CD player doesnt work anymore, and nissan is being a bunch of jerks.. so im just replacing it.
Old Sep 20, 2005 | 02:48 PM
Joshness's Avatar
Joshness
Oh, and I ordered the harness as metioned above, I will let you guys know if it works or not next week some time when all my parts get here :
Old Sep 26, 2005 | 11:42 PM
Joshness's Avatar
Joshness
FYI - Crutchfield Harness Worked, Part #120707550
Thanks!
HoBrahYouStink
Jun 24, 2016 10:58 PM
