idea for a sweet audio system
Old Dec 26, 2002 | 07:16 PM
eliminate's Avatar
eliminate
Arrow idea for a sweet audio system
without going into custom boxes, ive figured a great way to get some pretty pounding bass out of some small enclosures, right now i have 2 infinity basslink's mounted under the strutbar, for 10'''s these suckers hit pretty damn hard, they are efficient to, they have built in 200 watt class d amps and they only use >20 amps each box, this is a good way to go because u are not sacrificing any of the trunk space and still getting a good amount of bass.
Plan 2 is a little different a little more expensive but its a lot louder...
since i was always use to tremendous bass i aren't satisfied with the basslinks, they pound inside the car but its not as clear at high levels as i like to play it loud, i have 2 bazooka 10'' bass tubes on the way they should be here by tomorrow, there the 10'' dvc sub tubes that can handle 500 watts rms 250 to each coil, im going to power both thies bad boys with a lanzar vibe 1200D amp that puts out about 1250 watts RMS at 1 ohm, its a discontinued amp but i found 1 for about 250$ new, im going to add another capacitor, go from 4 gauge to 2 gauge and add a higher amp battery if need be.
since the subs have 104 DB efficiency and they handle 500 watts rms each and they play best when fired into a corner, having them both placed facing the back 2 corners of the car under the strut bar with the amp mounted in the middle, this will be 1 of the loudest, clearest sounding systems ever put into a z without going into custom boxes.
Old Dec 26, 2002 | 08:02 PM
JZC's Avatar
JZC
Sounds nice
Pounding bass is not my cup of tea but that sounds great for you.
Let us know how it turns out.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
