Front Door Speakers: Spacer Size?
Old Oct 26, 2005 | 07:49 AM
isugoo's Avatar
isugoo
Default Front Door Speakers: Spacer Size?
Hi, I replaced my front speakers to Boston Accoustic SL60 component system and now its hitting corner of window.
Since Z door isn't really deep, I'm afraid to put spacers. What size spacer do you guys use to install front speakers?
Thanks in advance!
Old Oct 26, 2005 | 08:22 AM
dannichols's Avatar
dannichols
3/4 in to 1.5 in. Some have had luck building angled spacers, or offsetting the hole in the spacer to raise or otherwise move the speaker further towards the center of the door opening. Speaker depths will range from 2" to 3"
Old Oct 26, 2005 | 08:36 AM
lightner22's Avatar
lightner22
I used a 1 inch spacer I made from mdf. Worked perfect on the passenger side. On the drivers side I couldn't get it to clear the door panel so I cut it back to 1/2 inch and it hits the window now. Over the window I'm redoing the drivers side from scratch. I have infinity 6.1s BTW.
Old Oct 26, 2005 | 10:21 AM
isugoo's Avatar
isugoo
thanks for replies.
my boston sl60's Mounting Depth is 2-7/16" (62.0mm). i will begin with using 1" mdf.
Old Oct 26, 2005 | 10:42 AM
Art Vandaleigh's Avatar
Art Vandaleigh
I used 1" metra spacers for my infinity components.
Old Oct 26, 2005 | 10:51 AM
isugoo's Avatar
isugoo
That's sweet!
I don't have to deal with MDF any more!
Does it work/fit well?
For some people's reference, here is a link from Circuitcity.
http://www.circuitcity.com/ssm/Metra...oductDetail.do
(if this doesn't work, go to www.circuitcity.com and search for metra spacer. there is only one.)
Old Oct 26, 2005 | 11:34 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I tried 1" plastic spacers with my Infinity 6.1's and they were just a tad too shallow so I made mine out of plywood. Off setting them a bit toward the front of the car helps too.
Old Oct 26, 2005 | 05:25 PM
350xfire's Avatar
350xfire
Tear up the piece of crap Bose speakers and use the plastic mounting adapter...
Old Oct 26, 2005 | 09:31 PM
isugoo's Avatar
isugoo
I feel your anger. I would love to do it but since I'm leasing this, I'm planning Bose back up again when time comes....
seagrasser
Oct 11, 2015 03:27 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
