Aftermarket battery...
Old Nov 7, 2005 | 03:13 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
+2, I need to upgrade my battery in the near future and was looking at Stingers but don't know which one I should get.
Old Nov 7, 2005 | 03:38 PM
jdg345's Avatar
jdg345
According to Sears Automotive, we need a Group 35 Battery for our cars ...
Length 9-11/16 in.
Width 6-7/8 in.
Height 8-7/8 in.
Trying to find someone that carries Optima, Stinger, or Orbital locally at this point is quite the challenge ...
Old Nov 11, 2005 | 08:13 PM
jdg345's Avatar
jdg345
How about this Stinger? It looks like the ideal fit ... the other options are too small or too large ... and this should be more than enough ... thoughts:
It's the Power2 SP1000 ...
http://www.cardomain.com/item/STISP1000
Old Nov 12, 2005 | 05:40 PM
jdg345's Avatar
jdg345
I just found an awesome deal on this Power2 SP1000 ... I'm going to try to fit it tomorrow if I get some time ... It's close to the size of the factory battery ...
Old Nov 23, 2005 | 08:08 PM
mickey99us's Avatar
mickey99us
Originally Posted by slvr_g35
I'm using the Red on my G, but the terminals are reversed so you'll have to make extensions for your battery terminals if they are similar to the G.
very true. i got a red top and i had to make new wires because the stocks were to short and the posts were reversed. damn it was a ***** to get the damn thing in there.
Old Nov 24, 2005 | 05:17 AM
gringott's Avatar
gringott
Keep us informed. I am in the market
Old Nov 24, 2005 | 06:57 AM
GEE PASTA's Avatar
GEE PASTA
http://www.1st-optima-batteries.com/index.html
Try this red top model # 34r
Yellow top d51r & d35 I went with the d35
This place had the best prices and shipped that day. Free shipping and no taxes.
Old Nov 24, 2005 | 07:58 AM
gringott's Avatar
gringott
At the optima website, if you put in 2003-2004 350Z, it says no matches.
Old Nov 24, 2005 | 09:23 AM
jdg345's Avatar
jdg345
Yah, they only seem to match up the red top for our cars, not the yellow top ... not sure why. I left my installer with the Stinger Power2 SP1000 and he says it doesn't fit right either as it's not the same size ... Anyone else with the Stinger installed have any tips on how to make it fit?
Old Nov 24, 2005 | 06:05 PM
GEE PASTA's Avatar
GEE PASTA
Odyssey makes the stinger. And for many others.
http://www.odysseyfactory.com/product_list.htm
Old Nov 25, 2005 | 06:48 PM
clkwrkorg36's Avatar
clkwrkorg36
the spv33 will fit no problem
Old Nov 25, 2005 | 06:52 PM
clkwrkorg36
i think the correct #is spv 44
Old Nov 25, 2005 | 08:27 PM
jdg345's Avatar
jdg345
The SP1000 seems like it's too short and the threads for the mount don't make it ... any suggestions on where I can extend the mount or something?
Old Nov 26, 2005 | 07:24 AM
xtrememan315's Avatar
xtrememan315
I'm running the same amps as you are and I got the Rockford Fosgate battery and it works pretty well. I am very happy with it!
Old Nov 26, 2005 | 12:25 PM
clkwrkorg36
a batcap 800 will also work. batcap.net
Old Nov 26, 2005 | 12:49 PM
MySunset350Z's Avatar
MySunset350Z
if saving weight is your goal, then the yellow top is not the way to go. the odyssy (spelling) pc680 would be your best bet. something around 12-13lbs depending on wheather or not you get the metal jacket. the stock battery is somewhere in the 35lb range. the cranking amps were more then enough to start my car in the freezing cold, i just cant remember the exact number.
i had to sell it because i needed the extra power for my nitrous system. i wouldnt recommend it if you have an aftermarket sound system, FI or anything of that sort that can easily drain the battery. this is for those N/A guys.
Old Nov 26, 2005 | 06:26 PM
808_FairladyZ's Avatar
808_FairladyZ
Rockford Fosgate uses Orbital Batteries as their own. FYI.
Old Nov 26, 2005 | 06:40 PM
  #38
808_FairladyZ
I did not know that Optima offered a "Light weight" Battery. The Optima batteries that we sell are not light by any means but it is far more superior then your average OEM battery. FYI, yes it is true that the Optima Red tops have a higher rated CCA but it is not a deep cycle battery like a Yellow top which would, if drained, cause it to lose its abillity to fully charge like your standard battery. Fyi, Optima batteries due contain sulfuric acid but not in the same manor as a standard battery.
Installing a Yellow Top Battery in my car required me to extend my power wire and also replace my ground wire( which was a given anyhow).
Old Nov 26, 2005 | 06:56 PM
  #39
808_FairladyZ
Also, we don't deal with orbital but we did sell Rockford Fosgate Batteries at one time and they use Orbital batteries. I don't know much about Orbital as a primary brand but i do know that they do have deep cycle batteries. They do not however contain the "Spiralcell Technology" that Optima does. How this technology sets these batteries apart i'm not sure but the Deep Cycle Rockford Fosgate Batteries that we did sell worked as well as the Optima Yellow Tops and they even cost the same at that time. They did the same thing in my opinion but again, i'm not entirely sure and my info. could be subject to debate.
Old Nov 26, 2005 | 07:34 PM
  #40
jdg345's Avatar
jdg345
All Great Info! Thanks!
... but any tips on how I can get the battery actually mounted? This thing is like 2" shorter than the stock battery so the mount doesn't work
