Aftermarket battery...
Old Nov 2, 2005 | 06:52 PM
ss350's Avatar
ss350
Default Aftermarket battery...
Hey guys, my battery is dead and I'm thinking about getting an aftermarket one. What batteries should I consider? I searched and found many of you have gone with the optima lightweight battery. But doesn't this battery provide less cranking amps and less reserve than the stock battery? This optima battery is in a different group (51), as opposed to the stock which i belive is in group 34.
Will the lightweight optima work fine?
BTW I'm running a Jl 500/1 and 300/4 amps
thanx
Old Nov 2, 2005 | 07:24 PM
usmanasif's Avatar
usmanasif
Optima. Best battery out there. It isn't due to the weight only. Optimas are solid state batteries, so no acid. They can be placed at angle and are very durable.
Old Nov 2, 2005 | 07:42 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
That's exactly what I run on my Optima Lightweight Yellowtop. No issues so far, had it around a year.
Old Nov 2, 2005 | 08:18 PM
Mike Wazowski's Avatar
Mike Wazowski
+1
I love my Yellow Top, starts easier and have no noted drain. I also run the 500/1 and 300/4 amps.
Old Nov 3, 2005 | 02:57 PM
pingrr's Avatar
pingrr
I have an optima yellow top in my Eclipse (I don't know if it light weight or not). I am running two 12" L7's with two kicker 850.2 amps with no problems at all.
I would highly recomend the yellowtop.
Old Nov 3, 2005 | 03:02 PM
pingrr's Avatar
pingrr
Old Nov 3, 2005 | 03:05 PM
2slow4me1990's Avatar
2slow4me1990
yellow top :]
Old Nov 3, 2005 | 04:43 PM
ss350's Avatar
ss350
are all of you using the lightweight yellow top or regular yellow tops?
Old Nov 4, 2005 | 05:29 AM
cehome's Avatar
cehome
Isn't the yellow top for those who intend to run their after market stereo with the car off. Would not the Red tops be better for an all around battey? It offers better Cold Cranking Amps than yellow tops.
Old Nov 4, 2005 | 06:08 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
lightweight one here, I'm not sure if they offer a "light" red top, that's why most are using the yellow.
Old Nov 4, 2005 | 07:29 AM
NisAznMonk's Avatar
NisAznMonk
You could also look into www.kinetikaudio.com
Old Nov 5, 2005 | 12:00 AM
slvr_g35's Avatar
slvr_g35
I'm using the Red on my G, but the terminals are reversed so you'll have to make extensions for your battery terminals if they are similar to the G.
Old Nov 5, 2005 | 12:12 AM
jdg345's Avatar
jdg345
When I do a search on optima's website for a match, it says that there are no batteries available for the 350z ... is there a best match yellow top?
Old Nov 6, 2005 | 09:08 AM
jdg345's Avatar
jdg345
Anyone with suggestions on what group/model battery to buy? I went to autozone yesterday and the only thing that come up in the system was a Red Top, Group 35.
Old Nov 6, 2005 | 10:23 PM
slvr_g35's Avatar
slvr_g35
I have the Red 34/78
Old Nov 7, 2005 | 06:51 AM
jdg345's Avatar
jdg345
Would it be the same group for yellow?
Old Nov 7, 2005 | 02:27 PM
LS350Z's Avatar
LS350Z
Charter Member #56
In competition we've found that Stinger batteries out perform Optima batteries across the board (amps, durability, and longevity). Either battery is better then stock, but in competition (we compete Nationally in sound quality and sound pressure events in dBDrag, MECA, & IASCA in 4 different vehicles).
Old Nov 7, 2005 | 02:29 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
There is an order code for the yellow tops to get the terminals on the correct side ... (R) I think.
Old Nov 7, 2005 | 02:30 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
What's the model/part number you're using?
Old Nov 7, 2005 | 02:54 PM
jdg345's Avatar
jdg345
+1 on Paul's Request ... Also, any feedback on Orbital?
Mostly, I just need to know which p/n fits in the stock location for our cars ...
