Mounting basslink in stock sub location
Old Nov 8, 2005 | 05:50 PM
texasGJ's Avatar
texasGJ
Default Mounting basslink in stock sub location
Hi,
I've seen a few opinions about this, but wanted to see if there was a consensus...
What is the best way to mount the basslink in the stock sub location? From what I've seen so far, it looks like the best bet might be:
mount it to the top of the compartment, sub firing downwards
Any opinions? Getting this installed on Thursday.
Thanks!
Old Nov 8, 2005 | 05:54 PM
lightner22's Avatar
lightner22
That is the only way I could get it to fit. You can fire it up or down, those are your choices. MIne took a while to get mounted and its only held in by two screws due to the f-ed up shape of that area and difficulty getting screws to tap in to the sheet metal.
Old Nov 9, 2005 | 08:17 AM
desiZ's Avatar
desiZ
believe it or not, my basslink is held in place with zip-ties. Reason is that its an extremely hard area to get to, to install the screws. Ended up using zip ties and its been rock solid for the past 6 months.
- happy camper
Old Nov 9, 2005 | 09:05 AM
lightner22's Avatar
lightner22
What did you zip tie it to? Did you drill holes or just use existing ones? I still need to go back in and make my install more secure but it hasn't moved in 4 months or so, so it's probably not going anywhere...knock on wood.
Old Nov 9, 2005 | 09:30 AM
desiZ's Avatar
desiZ
existing holes.. here's a pic...
Old Nov 9, 2005 | 11:09 AM
pingrr's Avatar
pingrr
I have my basslink mounted like the above picture however I was able to bolt iit down
Old Nov 9, 2005 | 11:15 AM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
Is it easy to remove? I would like to make it modular when I hit the track.
Old Nov 9, 2005 | 12:47 PM
pingrr's Avatar
pingrr
No, it's a very tight fit. Getting the screws on the back side is very dificult. The basslink isn't that heavy. The hole unit probably only weighs around 30 lbs.
I have seen some people who only bolt the front of the unit. If you set it up like that it may be relativly easy to remove.
Old Nov 9, 2005 | 03:36 PM
anotheraznguy's Avatar
anotheraznguy
http://www.crutchfield.com/S-o3DzbDd...0&I=108BASSLIN
is this the one you guys are using?
Old Nov 9, 2005 | 04:16 PM
desiZ's Avatar
desiZ
yup thats the one i'm using...
it is pretty heavy .... and making it modular would be pretty simple charlie... for an auto-pro like u
Old Nov 9, 2005 | 06:14 PM
charlie_rdstr_Z
Lol the electrical parts are confusing for me. So many wires and colors and zap zap my hair sticks up.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Tochigi_236
Sep 27, 2015 03:40 PM
