Reverse Lamp Wire For Backup Camera? Where is it?
Old Nov 9, 2005 | 07:57 AM
milkit's Avatar
milkit
Default Reverse Lamp Wire For Backup Camera? Where is it?
Im about to go outside and install my new kenwood ddx7017
This deck has automatic switching to the rear camera input when the car is put in reverse, but you are required to connect the wire to the "Vehicle's Reverse Lamp Harness"
My question is, where the heck is that!?! Please someone help me out if you know!
Old Nov 9, 2005 | 09:56 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I intercepted mine in the left wheel well to avoid running wires though the already tight console area. My "brain" is mounted under the passenger's seat. It's just behind the strut bar area so if you take out that piece of plastic - the one that forms the bottom of the triangle window - you'll see three jacks running to the harness back aft.
The wire does run though the left kick panel somewhere ... I didn't want to go there because of the "fine" job the Nissan dealer did with the installation of my alarm system.
You can see the safety pin in the jack from testing.
Here's a close-up.
Old Nov 9, 2005 | 11:59 AM
milkit's Avatar
milkit
thanks, mine will actually be coming from the dash bc its a DD with brain in dash too, but thanks very much! i should be able to get it just fine now
Pleask
Dec 21, 2021 03:17 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
Tochigi_236
Sep 27, 2015 03:40 PM
