Spare Tire Sub Box
Old Nov 13, 2005 | 12:07 PM
mlg9770's Avatar
mlg9770
ZEnclosures
Default Spare Tire Sub Box
I finally had some free time and designed a sub box for the spare tire compartment. Here are a couple pics....I will post some more when I get it carpeted tomorrow and some pics of the 1-12" version.
The box for 2-10" subs will have approx. 1.48 cu airspace with 7 5/8" mounting depth. The 1-12" version will have approx 1.30 cu ft with 7 5/8" mounting depth. The box is fastened down with the factory tire bolt and a piece pvc as a collar to seal the box....this worked out great.
You have to cut two small corners out of the foam that surrounds the spare tire..it took me about 2 minutes. Also, you have to cut your trunk mat around the raised panel. I could also cut a new matching trunk mat with the carpet I cover the box in so the factory mat does'nt have to be cut up.
mike
Attached Thumbnails Spare Tire Sub Box-dsc02984.jpg   Spare Tire Sub Box-dsc02985.jpg   Spare Tire Sub Box-dsc02986.jpg   Spare Tire Sub Box-dsc02988.jpg
Old Nov 14, 2005 | 07:28 AM
mlg9770's Avatar
mlg9770
ZEnclosures
Does anyone know if the ZR spare tire compartment is the same as the coupe? I was hoping this would be an option for the Roadster.
thanks in advance
mike
Old Nov 14, 2005 | 09:49 AM
VO...'s Avatar
VO...
Administrator
Nice job.
Old Nov 14, 2005 | 02:20 PM
mlg9770's Avatar
mlg9770
ZEnclosures
Here are some pictures of the 1-12" box finished.
mike
ZEnclosures
Attached Thumbnails Spare Tire Sub Box-dsc02989.jpg   Spare Tire Sub Box-dsc02990.jpg   Spare Tire Sub Box-dsc02993.jpg
Old Nov 14, 2005 | 02:47 PM
stinkboy's Avatar
stinkboy
doesnt seem deep enough for a bad *** sub. jl audio 12w7 has 9.5 inches from the under side of the mount. guess it could fit a 12w6.
Old Nov 14, 2005 | 02:49 PM
stereoneeds's Avatar
stereoneeds
are you going to be selling these?
Old Nov 14, 2005 | 02:51 PM
stinkboy's Avatar
stinkboy
however the Z doesnt need too much thump its a small car. i think 2 -10" would look the best overall. two 10w6 with a jl audio 1000/1 mono block amp would kill that car.
so i ditto the question, coupe tire area and roadster tire area, are they the same or not?
Old Nov 14, 2005 | 02:53 PM
stinkboy's Avatar
stinkboy
between the pods and this sub box, im thinking ill have to upgrade my stereo except use the jl audio cleansweep product so i can keep the HU. although i nice dvd touch screen would be bad ***.
i really like the pods and if this works in a roadster and they are forsale, im going to upgrade for sure.
Old Nov 14, 2005 | 03:17 PM
mlg9770's Avatar
mlg9770
ZEnclosures
Yes, I will be selling them starting this week. I will start listing them on eBay in a couple of days. This is the first one I've made and its up for grabs. I'm going to be selling them for $125. If anyone's interested in the first one I'll throw in shipping.....I'm anxious to get some feedback.
Hopefully tomorrow I will have the 2-10" box carpeted and post some more pics.
thanks mike
Old Nov 14, 2005 | 03:36 PM
05-Z's Avatar
05-Z
Nice. How heavy is this box?
Old Nov 14, 2005 | 04:07 PM
mlg9770's Avatar
mlg9770
ZEnclosures
The 1-12" box is 31 lbs. The 2-10" is 36 lbs.(The spare tire weighs 30 lbs)
thanks mike
Old Nov 14, 2005 | 06:33 PM
Badfish25's Avatar
Badfish25
I was going to redo My system with a box similar to that, for 125 I'll just buy one of those!!!
Anyway you can make a single 12" version but without such a big hump the sub is mounted too? my sub only needs 6.75" depth, would love it if you could make a sunk in baffle.
Any chance?
Old Nov 14, 2005 | 06:55 PM
mlg9770's Avatar
mlg9770
ZEnclosures
Any chance?
The box without any spacers (totally flush with the factory carpet) has 5.25" of depth. On this box I basically added three spacers to give it a hair over 7.5" of depth. I can add or subtract spacers on the box as needed.. + or - .75" per spacer. I can do a counter sunk panel but it will make the mounting area even larger.
thanks mike
Old Nov 14, 2005 | 07:32 PM
Badfish25's Avatar
Badfish25
good point on the extra mounting area, where in florida are you?
Old Nov 14, 2005 | 07:35 PM
dannichols's Avatar
dannichols
This is why I chose the MBQ RE302 with 5.5" depth. The dual carpets in the rear will add about 1/4" or so to flush..so flush would need to be spaced up a little bit.
Old Nov 15, 2005 | 03:58 AM
mlg9770's Avatar
mlg9770
ZEnclosures
I'm in Sarasota which is about 50 minutes south of Tampa.
Old Nov 15, 2005 | 04:42 AM
SkiTTlez's Avatar
SkiTTlez
mike
ZEnclosures
LOOKS VERY FAMILIAR! dammit. i thought i was being original
Old Nov 15, 2005 | 04:58 AM
mlg9770's Avatar
mlg9770
ZEnclosures
[QUOTE=SkiTTlez]LOOKS VERY FAMILIAR! dammit. i thought i was being original
Looks Good! I like the trim ring...
How's it sound?
Old Nov 15, 2005 | 06:21 AM
SkiTTlez's Avatar
SkiTTlez
[QUOTE=mlg9770]
How's it sound?
sounds ridiculous! i wasn't expecting it to sound the way it does to be honest. hits very hard, and gets really low as well....surprising for a sealed enclosure. basically we have the same box
Old Nov 15, 2005 | 07:22 AM
dannichols's Avatar
dannichols
Had to post mine again too. Sound is incredible. I'm running a 12" MBQUART. I had a 10" strut box before..no comparison..The tire well mount does not trap bass. Mine is 6" deep.. I added a 1/2" MDF ring to the top to sit near flush with the floor. Fiberglass bottom and sides to add depth.
Attached Thumbnails Spare Tire Sub Box-subdan2.jpg   Spare Tire Sub Box-subflat.jpg   Spare Tire Sub Box-subxx1.jpg
