Kenwood DDX8017 Crossover question
Old Nov 15, 2005 | 05:45 AM
TxTitan's Avatar
TxTitan
Default Kenwood DDX8017 Crossover question
If I have a crossover already installed will I need to remove it when I install this new head unit?
* In-Dash DVD Double DIN Touchscreen Multimedia System
* Double DIN Size
* Motorized 6.5" LCD Screen with Adjustable Angle
* Touchscreen System Control
* Wireless Remote Included
* DVD, DVD+/-R, DVD+/-RW, CD-R/RW, MP3/WMA Disc, VCD, JPEG, and MPEG1 and 2 File Compatible
* RMS Power Rating: 22 Watts x 4 Channels
* Peak Power Rating: 50 Watts x 4 Channels
* Built-In 5.1 Channel Surround Sound Decoder
* SRS CS II (Circle Surround II): Simulates Surround Sound with Stereo Input Sources
* SRS WOW
* 4-Band Parametric EQ
* Digital Crossover System
* Telephone Mute
* Installer Memory: Saves Settings While Power is Disconnected
* SIRIUS, XM Satellite Radio controls (tuner, antenna, and subscription required and not included with purchase)
* Compatible with Kenwood's iPod Control Interface
* HD Radio Ready (Kenwood HD Radio Tuner Required and Not Included)
* CD Changer / TV Tuner Controls
* Rearview Camera Input
* Compatible with Newer Kenwood Navigation Systems
* RCA A/V Inputs: 2 Sets
* A/V Output
* Dual-Zone Capable
* 5.1 Channel RCA Outputs: 3 Pair (Front, Rear, Sub) + Center
* Preamp Voltage: 5V
* CR-2 Radio Tuner
* 18 FM / 6 AM Station Presets
* DVD Player Freq. Response: 20 Hz - 22 kHz
* FM Sensitivity: 9.3 dBf
* Region 1 DVD Player
* 1-year Sonic Electronix warranty
In-Dash Receiver Specifications:
* Faceplate Security None
* CD-R/RW Playback Yes (CD-R, RW)
* MP3 Playback Yes (MP3, WMA)
* DVD / Video Playback Yes (DVD+/-R, +/- RW, VCD)
* Remote Control Yes
* Peak Power Output 50 watts x 4 chan.
* RMS Power Output 22 watts x 4 chan.
* Preamp/RCA Outputs Yes - 3 Pair (Front, Rear, Sub) + Center
* Preamp Voltage 5V
* Built-In Equalizer 4-Band Parametric EQ
* Display Color 6.5" TFT
* Button Color Red / Green
* CD Signal-to-Noise 95 dB
* CD Changer Controls Yes
* Satellite Radio SIRIUS, XM Satellite Radio Ready
* AUX Input Yes - 2 Set A/V
* Warranty 1-year SE
Old Nov 15, 2005 | 07:40 AM
THEDUKE's Avatar
THEDUKE
Get rid of your crossover. Most likely the one in the Kenwwod is much better than the DLH one you have. Also you will have less components in your system which means less wiring and less noise.
Old Nov 15, 2005 | 08:26 AM
THE TECH's Avatar
THE TECH
Also, your amps may have x-overs in them too. The less components you have, the better.
Old Nov 16, 2005 | 02:57 PM
TxTitan's Avatar
TxTitan
Ok, thx for the advise. One other question I only have 1 amp for the front and rear speakers and the head unit has front and rear preout, so do I use a 4/2 rca wire and just plug that into the amp? I guess the only thing I loose is fading. I can use the amp gain to do that right?
Old Nov 16, 2005 | 03:03 PM
THE TECH's Avatar
THE TECH
Well depends if your amp is four channel or two. For a two channel amp, just run the front outputs to the input of your amp. For four channels, it's obvious.
Old Nov 16, 2005 | 04:38 PM
TxTitan's Avatar
TxTitan
Well now I feel stupid, it's a four channel amp..
issyz
Jul 2, 2017 03:04 PM
dcains
Nov 11, 2015 11:36 PM
Alexreyes
Sep 30, 2015 11:30 PM
