Eclipse HU ESN Problems
Old Nov 20, 2005 | 01:10 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Default Eclipse HU ESN Problems
I disconnected my battery to install XM in my car, thinking that I knew which CD I used to set up my ESN security. I tried the CD and it doesn't work. Is there any way that I can bypass the ESN security?
Old Nov 20, 2005 | 05:14 PM
isugoo's Avatar
isugoo
It must work (and it worked for me when I reconnect battery).
But if its not working for some reason, you can contact Eclipse AVN support. You can find ph# from their webstie.
If you bought it from authorized dealer and registered it, you will not have much problem solving that issue. Good luck.
Old Nov 22, 2005 | 04:40 PM
Spartan1510's Avatar
Spartan1510
This happened to me about 7 years ago with the ESN security system. The cd that I THOUGHT (and still think to this day) was the key cd didn't work. I had to send the HU back to Eclipse with a copy of my Eclipse certificate for them to unlock from the factory (or service center). Cost wasn't bad, just a PITA.
When the radio got back and went in the car I decided not to setup the security CD.
Problem didn't happen again.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
