Rearview Camera
Skidazzle has direct experience with this in his Z, if I remember correctly...I think he is the only one I have seen with a backup camera linked into his nav system.
Essentially, all you need to do is find the reverse backup wire, and wire in a relay to put he nav system into a mode so that the nav screen displays the backup camera picture when the Z is in reverse. Obviously, you have to have a means of converting composite video output from the camera to rgb for the screen.
If you had the FSM (like I do), the wires you need to tap should be easy to find. I am considering installing a backup camera myself, but I am trying to figure out how to link it in using a Pioneer GEX-P7000 tuner. So far, I haven't gotten it totally figured out.
Tochigi_236
Sep 27, 2015 03:40 PM
