Remote with factory head unit
Old Dec 14, 2005 | 10:12 AM
Fletch69z's Avatar
Fletch69z
Default Remote with factory head unit
Ok,
I haven't done stereo stuff for a while and I forget this. It's probably something really stupid that I should know so I apologize. But how do you set up a sub without changing out the head unit. I know there's obviously power and ground and then I'm using one of those things (can't remember what they are called) that you hook up to the two wires of the rear speakers and it converts it to a mono output that you plug into your amp to get signal to your sub. But what would you hook the remote wire to so that it (the amp and sub) come on when you start the car and shut off when you turn off the car? Any advice on how to go about running the wires would be appreciated too (I know there are threads on it and I've already printed those out, but if there were any problems anyone had, let me know). Thanks!
Fletch
Old Dec 14, 2005 | 10:39 AM
milkit's Avatar
milkit
line out converter will be needed
Old Dec 14, 2005 | 11:59 AM
Fletch69z's Avatar
Fletch69z
Yeah! That's what that thing is called! I couldn't remember what it was called. But what about the remote wire?
Old Dec 14, 2005 | 01:09 PM
lightner22's Avatar
lightner22
Just tap into the rear 12v accessory outlet. That's what I used on mine...it will be on as long as your car is on, but my stereo is always on anyway.
Old Dec 14, 2005 | 05:48 PM
Fletch69z's Avatar
Fletch69z
So, you mean the outlet in the bulkhead? And which wire would I tap into? My stereo's on all the time too and as long as it goes off when my car goes off that's all that matters. Thanks!
Old Dec 25, 2005 | 01:36 AM
cmeissen's Avatar
cmeissen
Did you find out which wire would need to be tapped into?
Thanks
May 30, 2017 03:28 PM
dcains
Nov 11, 2015 11:36 PM
Depravity
Oct 1, 2015 04:49 PM
