$5 do it yourself door speaker pods
Old Jan 21, 2006 | 02:27 PM
mlg9770's Avatar
mlg9770
ZEnclosures
Default $5 do it yourself door speaker pods
I was bored the other day so I decided to make myself a pair of door speaker mounts. Tools used: high speed disc sander, router(jigsaw will work),drill.
I Glued two pieces of 3/4" mdf together to get a 1.5" thick piece of mdf.
I traced the factory speaker cover and then added 3/4" all the way around for a mounting lip.
Basically sanded , test fit, and sanded until it followed the curve of the door panel.
Each side took about 30 minute of going back and forth sanding and test fitting. I cut my center hole out then vinyled using a spray adhesive.
I plan on screwing them to the door panel from the back.
anyway, just thought I'd share
mike
Attached Thumbnails  do it yourself door speaker pods-dsc03174.jpg    do it yourself door speaker pods-dsc03176.jpg
Old Jan 21, 2006 | 03:19 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Very nice!
Old Jan 21, 2006 | 07:50 PM
sharingan625's Avatar
sharingan625
that actually looks pretty good. nice work!
Old Jan 21, 2006 | 08:00 PM
done12many2's Avatar
done12many2
Fantastic work man! Very nice and inexpensive alternative to some high dollars applications. How are you securing them to the door? How are you going to seal them?
Old Jan 21, 2006 | 08:21 PM
Sully's Avatar
Sully
+1 sealing and securing? Thanks and nice setup!!
Old Jan 21, 2006 | 10:20 PM
TheBigGuyRy's Avatar
TheBigGuyRy
Y'know, if those are effective, you could probably make some pretty decent money selling to those of us who don't want to spend $250 on something like that...
Old Jan 22, 2006 | 04:45 AM
mlg9770's Avatar
mlg9770
ZEnclosures
I figure I'll screw them on from the back of the door for starters. If they don't seem secure enough I'll pull the vinyl off and put four bolts in, counter sink the heads, and re-vinyl. Then I'll mark where the bolt holes need to be, pre-drill thru the panel, then add lock washers and tighten them down.
I'm hoping when I screw/bolt them down the vinyl will act as a gasket. I'll post some pics once I get everything mounted.
thanks mike
Old Jan 22, 2006 | 05:58 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I wouldn't worry about the gasket action as you're going to have to seal the entire door panel in place to the door frame ... not good. For those looking for seals there are 6.5" foam rubber weather proofing cups that you can put in behind the speaker ... again not a perfect seal.
Old Jan 22, 2006 | 07:33 PM
03performz's Avatar
03performz
I'm not feelin' it man. They kind of look like earmuffs. If they were more seamless then I could see it but they totally look like after thoughts...the fiberglass look is a lot cleaner for example. Not tryin' to be harsh, I respect working with your hands just thought you might want a little constructive criticism.
Old Jan 23, 2006 | 04:12 AM
mlg9770's Avatar
mlg9770
ZEnclosures
I agree, they are different and fiberglass does look a lot cleaner. Once I get the speakers in and see how they sound and look I'll make the decision whether they stay or go.
thanks mike
3vilbunny
Jul 18, 2017 05:10 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
