System dimensions
Old Jan 19, 2003 | 10:04 AM
AAAA's Avatar
AAAA
Default System dimensions
Im seeing a lot of great systems posted here, really inspiring. Im just wondering if anyone knew the dimensions/sizes of the speakers cause i have a Z on order, but i want to have the sound stuff there and ready to install when it arrives (or at least start shopping now)
Thanks, and keep posting your install pics
A
Old Jan 19, 2003 | 12:32 PM
bastard's Avatar
bastard
There's posts about it, but as far as i know, all the speakers are 6 1/2s. The tweeters are in the sail panels in the doors and I believe they're 1". The subwoofer location will hold a 10" but the depth is probably a limitation due to the angle of the mounting bracket, and the sound of the area probably sucks due to the flex of the sheet metal. I would hesitate to use a freeair subwoofer in there, as it may cause resonances in the metal.
If you're considering a subwoofer in that location, you may consider a fiberglass drop-in kind of enclosure, which is something I have thought about, but I can't be sure until I actually have the damn car. =) MDF may work but I believe the thickness of the wood will greatly reduce the airspace you will have to work with to probably no more than .8 cubic feet. Fiberglass would allow a bit more due to the fact you can shape it into the area better.
The fronts need spacers, which you can either make out of MDF or get at Circuit City or Best Buy for probably $20 or less. I do not have my Z yet, so if I were you, I'd double check all this stuff because I might be remembering incorrectly.
Old Jan 19, 2003 | 04:05 PM
AAAA's Avatar
AAAA
Thanks a lot, i knew some of the speakers were 6 1/2, but i wasnt sure the fronts were too. Guess i better get digging through these forums, thanks. Im considering a sub install in the trunk, ive heard/read that the stock location just sucks... any ways . thanks again
A
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
