Do you REALLY need a sub?
Old Feb 13, 2006 | 07:15 PM
Kabs's Avatar
Kabs
Default Do you REALLY need a sub?
Im planning on getting a new HU and a 4-way amp for my speakers. Do i REALLY need a sub?
I dont need all that thump... i just need loud clear music =)
Old Feb 13, 2006 | 07:18 PM
dark_muppet's Avatar
dark_muppet
the question is do YOU really need one. Music is about preferance man, so if you don't want one don't get one.
16psibrick's Avatar
16psibrick
Simplicity in Sound
need? no, but then again, you dont even NEED speakrs or a headunit
but to get the full specturm of the sound, yes, a sub is needed...many thing a sub is just for "bumping", thats not true, a stereo system should be able to replicate the entire sound spectrum, not leave everthing sub 80hz or so blank, that owuld sound very dry and gutless...
this applies to all genres of music...
b
Old Feb 13, 2006 | 07:21 PM
SRT4 to 350Z's Avatar
SRT4 to 350Z
I have to agree with bing on that one... the sub is a must.
Old Feb 13, 2006 | 07:23 PM
tienlo's Avatar
tienlo
a little sub is fine for you i think.
Old Feb 13, 2006 | 08:22 PM
Sean's Avatar
Sean
+1
Old Feb 13, 2006 | 08:34 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
No.
Most good 6.5" speakers will go below 80 Hz and much below 40 hertz is masked/covered with road roar at speed. For a better sound, yes of course.
Old Feb 13, 2006 | 09:11 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
well, in my car i dont need a sub really, if gone unfiltered, my kicks can go down to about 30-35hz flat
but i dont thinkse amny people will be doing my kind of set up in a 350z
Old Feb 13, 2006 | 09:51 PM
Armitage's Avatar
Armitage
Yes, but not an insane-crazy setup.
Old Feb 14, 2006 | 08:14 AM
Kabs's Avatar
Kabs
thanks i was just wondering cuase apparently my speakeres are pretty good... and i dont want myt car to thump that hard...
What i wanted was a better sounding system than the stock one.
Old Feb 14, 2006 | 08:58 AM
If you want to get down and groove with the homies you are going to have to get a couple of boom-boom boxes.
Old Feb 14, 2006 | 09:18 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
kabs, like i said, its not about thumping, its about hearing the entire spectrum of the music...
wtih any other expereinces, as a human being, you want the full spectrum, would you like to drive your car with out first gear always? can you drive it with only 2nd thru 6th?: of course, but would you enjoy it as much
if your goal is a well blanaced sound system, i strong recommend going wtih at least a small sub, a small well built 8 in the right enclosure off of 150 watts will do wonders for your music
b
Old Feb 14, 2006 | 09:56 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I would ditch the back speakers, bridge the 2 back channels and add an 8 or 10. Then use your gain adjustments to dial in the amount of bass you want.
Chris
Old Feb 14, 2006 | 09:23 PM
sintaxeror's Avatar
sintaxeror
Just spend the money on a nice set of components, and make sure the mids are sealed up. This is plenty for those who dont necessarily need the bass, and like to keep their trunks free.
Old Feb 15, 2006 | 05:06 AM
HyperSprite
Mad Scientist
"i just need loud clear music" was the request and once you start driving the mids hard you will either have a muddy midrange or little bass.
He could certainly start without a sub and see if he likes it, there is no harm in that.
As for trunk space, it is all relative, there is no need to take up that much trunk space to add a little bass.
Or you can go for a stock location box and take up no trunk space.
Chris
Old Feb 15, 2006 | 05:58 AM
350Zenophile's Avatar
350Zenophile
What about running some 6.5" free-airs in the rear speaker locations...would provide support for the mid-low freq.
And seal the front door enclosure completely so the fronts can produce tighter bass.
Old Feb 15, 2006 | 06:53 PM
MeetJoeAsian's Avatar
MeetJoeAsian
I have focals 6.5" components in the doors and focal 2-ways in the rear...currently I'm running with a base-tube, which is very good if you're looking just got good clean bass....but I have an MTX 10" sub that I want to put in..I want it to go under the bar, but I don't want the entire space covered up cuz I need to slide my golf drivers diagonal in my trunk, and my golf bag is already taking up the majority of my trunk...any suggestion anyone?
Old Mar 7, 2006 | 04:47 AM
[]V[]addog's Avatar
[]V[]addog
Chris
I really liek that set up chris, nice and clean, doesn't take up alot of room. what size is that 12? what is it, what are you using to power it? how do you like it.
Old Mar 7, 2006 | 04:57 AM
nissansource's Avatar
nissansource
i just finished up my system last week on friday. ive had understrut now i have at your rear neck check out the pics. I changed out those crappy audiobahn for some KICKER CVT i think either way i have them running at 1ohm and kenwood x811d is running @ 1000watts 1ohm
Old Mar 7, 2006 | 07:06 AM
HyperSprite
Mad Scientist
It's a Polk 10" GNX104 powered by a Hiphonics Zues amp. It sounds tight and clean and for the amount of space I had to sacrifice, I think it does very well.
Chris
