What EXACTLY do i need to buy....
Old Feb 14, 2006 | 04:16 PM
Kabs's Avatar
Kabs
Default What EXACTLY do i need to buy....
Im planning on installing a new Headunit asap.
I will be getting the Pioneer P80MP
What exactly do I need to buy and from where to get thing up and running?
Din Conversion Kit?
New Wires?
Or do i just plug it in and bam it works =P
Old Feb 14, 2006 | 04:53 PM
pingrr's Avatar
pingrr
Does your car have factory Bose or not? That will be a big factor in what you need.
Old Feb 14, 2006 | 06:05 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Crutchfield has a "what fits my car" wizzard on their Internet sight which will give you the proper wiring harness interface. I highly suggest you get this $20 cable rather than cut off and splice into your car's wiring harness. Nothing beats soldiering over a nice plastic dash for 45 minutes for pure enjoyment. One slip of the pencil and you've burned dash, carpet, or burned leather seats.
If the headend you're looking at is a single DIN size unit you'll need a dash kit. I highly recommend the Mepro unit that is not the one carried by Crutchfield - the Mepro is stronger and a tigher fit. I bought the one from Crutchfield and returned it for the Mepro.
Old Feb 14, 2006 | 06:30 PM
Kabs's Avatar
Kabs
none bose
BTW i dont know how to solder
btw there are 2 kit units... which one?
Old Feb 14, 2006 | 06:54 PM
rmesola's Avatar
rmesola
you can use crimp butt ends to connect the wires... if you can put heatshrink tubing, better but not necessary... IMHO learn to solder... you can solder it on your table ahead of time before going to the car...
connect the HU wires to the harness you buy from the store and then connect that harness to the stock one...
bought my stuff from cardomain.com and it came with free harness and DIN adapter...
make sure you have long screw drivers that are magnetic...
it took me 1 hour to install a new HU... but I was doing it along taking my time...
Most difficult thing was unhooking the connectors which was frozen solid (I had to put that HU in in 30 degree weather - couldn't wait)
Old Feb 14, 2006 | 07:22 PM
drumminguy81's Avatar
drumminguy81
oh oh i have a kit that i would sell you cheap!!!! the kit i bought is made by metra fo 03-05.. it comes with 2 kits one for a double din head unit and one for a single din head unit i have double din so i only used that part so everything you would need is there for mounting. and if you want ill even pick up the right harness for you and ship it all to you in one box... let me know if you are interested... pm me and we can talk price.. ill cut you a deal though...
Old Feb 14, 2006 | 08:55 PM
Kabs's Avatar
Kabs
ill let u know man! thanks
right now im tryin to decide if i should get a hU and topspeed exhauist or just save up for a diff exhuast =P
Old Feb 14, 2006 | 10:16 PM
drumminguy81
ok well if you want it i guarentee i will sell it to you cheaper than you can get it anywhere else.
Old Feb 23, 2006 | 09:01 AM
Z33's Avatar
Z33
For future reference, these are the exact part #, should be ok for 03-05:
Metra PN 70-7550 - into-car harness
Metra PN 99-7402 - dash kit
AI PN NDK-740 - dash kit
Old Feb 23, 2006 | 04:34 PM
TeesZ's Avatar
TeesZ
Why replace your factory head unit, theres nothing wrong with it and no other head unit will look as good in that location! What you need is a 3Sixty. It will allow you to retain your factory radio and add aftermarket amps and speakers. The EQ in our car is severe and a LOC isn't a good solution. 3Sixty will analyze the inputs, sum the necessary inputs to gte a full range response (20 to 20) normalize, or flatten them out to give you a flat full range response. Check it out
at
http://www.carsound.com/cgi-bin/UBB_...8;t=010916;p=0
Old Feb 23, 2006 | 04:42 PM
Will Pwr's Avatar
Will Pwr
I used the Metra kit as well..and its great....currently I have a single DIN HU...and plan to switch to a double DIN later on, so I dont really need to get new kit when that time comes around.
and definately get a plug-in harness....
xinno
Mar 25, 2010 08:12 PM
-sin-
Aug 26, 2009 10:12 PM
