Radar Cord?
Old Feb 15, 2006 | 06:54 PM
A. Hubbard's Avatar
A. Hubbard
Default Radar Cord?
Anybody have any ideas on how to hide the radar detector cord?
Old Feb 15, 2006 | 07:09 PM
ericjackson's Avatar
ericjackson
yes, hardwire...run it through your roof then down
Old Feb 15, 2006 | 07:50 PM
SmokyTyrz's Avatar
SmokyTyrz
^ What he said.
Tuck it under panels on the way to the fusebox. If you have to, remove a knee panel or two (usually a couple screws, then pull horizontally and/or vertically to release the usual automotive clips).
Route your ground to a bolt touching metal. If you can find an existing ground strap (a bolt with a wire already going to it) then just use that.
Route your power (12v lead) to the fuse box. Use the cig light fuse. Take the power lead, strip off a small bit, wrap it around one of the fuse blades, then stick the fuse/wire combo back in. It's switched so your detector will turn off when the car is shut off.
I recommend adding an inline fuse from Radio Shack, rated approx 1-3a. Cut the power lead at some point close to the fusebox-side of the connection and then add the inline fuse at the cut. This is an added safety. If something should ever go wrong you don't want a fiery mess running through your dashboard.
Be sure to route away from moving parts and/or feet. Use zip ties. If you have to add wire length to your detector cord, I recommend soldering and shrink wrap instead of wire connectors.
And if you're not comfortable with all that then find a friend who is and offer beers.
Good luck!
-Smoky
Old Feb 15, 2006 | 08:13 PM
jeffie7's Avatar
jeffie7
https://www.escortradar.com/cp/cgi-b...pg=prod&ref=80
Not sure if you have a passport but this comes with the wire, and fuse.
sure you can get your own wire/fuse but for a few bucks more you can have it all done for you.
Old Feb 15, 2006 | 08:22 PM
boostintt's Avatar
boostintt
same problem here... i just got my z and this is what happened
see the cord...
Old Feb 15, 2006 | 08:38 PM
ssgohan434's Avatar
ssgohan434
u have an '03 dont u? I believe the 04.5's and definately the '05's have a dc output right under the dash on the passenger side so i dont have that problem
boostintt's Avatar
boostintt
haha funny
Old Feb 15, 2006 | 09:53 PM
imseksy's Avatar
imseksy
see the cord...
holy hell!! hahahh i never thought someone would actually do that... the 06's come with another power outlet down near the passengers feet.
Old Feb 15, 2006 | 10:14 PM
lamaz's Avatar
lamaz
Read this thread.
https://my350z.com/forum/audio-and-video/46814-passport-8500-install.html
-LamaZ
Old Feb 16, 2006 | 05:12 AM
johnk024's Avatar
johnk024
I just got the straight wire (instead of the curly one) and tucked it under the plastic then took a plastic putty knife and tucked into the crack of the dashpad up to the radar detector. The only place you can see the wire is when it goes over the vent.
Old Feb 16, 2006 | 05:37 AM
PerfZ's Avatar
PerfZ
Hardwired mine into the wiring for the rearview mirror. took like 10 minutes. Custom bracket from someone on motoring.
Old Feb 16, 2006 | 06:13 AM
zugbug's Avatar
zugbug
uh, can you say Cordless SOLO i.e. Passport?
Old Feb 16, 2006 | 06:15 AM
Fletch69z's Avatar
Fletch69z
Yeah, mine used to look like that but I went to radio shack and bought a phone cord with the wires exposed already at the other end and hard wired it to my mirror. See the above link I think to get directions.
Old Feb 16, 2006 | 08:57 AM
usmanasif's Avatar
usmanasif
Mike's Mount, I take it. He is a member here as well (but don't ask me for his login!)
Old Feb 16, 2006 | 10:41 AM
sluggoZ's Avatar
sluggoZ
I believe it's mike3348 who sells the mount with a Z logo!
Old Feb 16, 2006 | 06:12 PM
A. Hubbard's Avatar
A. Hubbard
Thanks for the input! Cordless seems the route to go.
Old Feb 16, 2006 | 06:23 PM
zugbug's Avatar
zugbug
Now that you have freed up that rear plug, it is the perfect place for that 30gb Ipod!
Old Feb 16, 2006 | 07:18 PM
StillAlive2029's Avatar
StillAlive2029
today i stripped the wires on the mirror and on a aphone cord and tested it out...works liek a charm..never new it would be that easy...talked to mike today and i am sending him $20 and he is sending me the bracket i need...1) cant beleive how easy it way and 2) its so much better than having that curly cord running down my dash...love it!
Old Feb 16, 2006 | 07:54 PM
waitin407's Avatar
waitin407
even better
https://my350z.com/forum/audio-and-video/103962-v1-install-display-in-mirror.html
Old Feb 17, 2006 | 09:18 AM
jenna350z's Avatar
jenna350z
If you have the cig power plug under the passenger seat use that and run it through the dash and through the top vents.
