Instructions for disassembly
Old Feb 16, 2006 | 07:24 PM
sundevil67's Avatar
sundevil67
Default Instructions for disassembly
OK guys, I did something really stupid. I accidentally hit the "eject" button on my Omnifi, which is usually how you detach the faceplate. However in my specific installation, it cannot be removed. Therefore I now have a partially detached face, so the unit no longer powers up. So basically I need to take apart the entire rear part of the car to get behind the unit. I really don't want to pay the audio installer to do this, so if I could just get behind the thing I could snap it back into place. Anyone know where I can find some step by step instructions here? Thanks.
Old Feb 17, 2006 | 09:00 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Dang, you've got a bit of a job on your hands.
You have to pull the plastic from the back of the area, then the plastic from the front - and finally the one piece that wraps around the top - removing lots of the side panels in the process.
Old Feb 17, 2006 | 09:15 AM
XtaZee's Avatar
XtaZee
Download the 2004 Service Manual here.-
http://www.rippedzone.no-ip.org/File...ice_Manual.zip
Step-by-step instructions for removing interior trim are in the 'ei' section. Good luck.
Old Feb 17, 2006 | 09:31 AM
sundevil67's Avatar
sundevil67
Damn - I don't think I am going to attempt it then. It would take me days and I would probably put it back together wrong. It is just such a shame because now I am going to have to wait until I can afford to do the subs and the amp before I get this thing working. And I can't even get the home version working because it is so complicated. Don't buy one of these things (the Rockford Omnifi) - there is a reason why the product was quickly discontinued.
Old Feb 17, 2006 | 09:54 AM
sundevil67's Avatar
sundevil67
Do you guys agree that this is beyond moronic? How could they install something where you could accidentally hit a button that requires you to take apart the entire car to fix it. Its amateur hour over here. I am going to have this thing completely redone.
Old Feb 17, 2006 | 10:45 AM
dream724Z's Avatar
dream724Z
>Do you guys agree that this is beyond moronic? How could they install something where you could accidentally hit a button that requires you to take apart the entire car to fix it. Its amateur hour over here.<
Absolutely! A component should never self-destruct with a button push.
Would a thousand monkeys with typewriters given a thousand years write a great novel?
Old Feb 17, 2006 | 11:45 AM
sundevil67's Avatar
sundevil67
I think I am just going to walk away. I took a big chance bringing my car back to this guy to repair other items - they are a careless and unprofessional shop. The smart thing to do is to just cut my losses and have the next shop do it right.
Old Feb 17, 2006 | 11:52 AM
dream724Z's Avatar
dream724Z
Great Decision! Never let proven incompetent folks attempt to fix their mistake and then create new problems.
Old Feb 17, 2006 | 12:02 PM
sundevil67's Avatar
sundevil67
I think so too - I can just picture spending a day to fix it all and then have a passenger that doesn't know any better try to operate the thing when I'm not paying attention and cause it to happen again. It is almost a sure thing that it will happen by accident again. I think I want to have some custom doors fabricated to hide it anyways. The other "mail slot" was hanging out partially and didn't close properly when I got the car back. There were also missing screws and other panels that weren't secure. Very sloppy work. Though by installing it this way, he was able to mold a trim panel that eliminates any space around it. The next guy will need to come up with a creative solution to retain this type of clean look without hindering the intended operation of the unit.
Old Feb 17, 2006 | 12:41 PM
XtaZee's Avatar
XtaZee
+10000000000000000000000 Should be said of Nissan dealers.
Old Feb 17, 2006 | 01:24 PM
rmesola's Avatar
rmesola
couldn't you go into the other opening and push it from behind...
removing the back panel is a PITA... I know coz I just stripped by trunk/speaker area for sound dampening...
nanotech
Oct 2, 2015 05:02 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
