Found a direct speaker replacement for the BOSE
Old Feb 25, 2006 | 08:04 AM
zand02max's Avatar
zand02max
Default Found a direct speaker replacement for the BOSE
http://www.crutchfield.com/S-kBiDnOm...asp?i=108607CS
cheaper here, http://www.etronics.com/product.asp?...re=&catid=5767
I am sure you can get them somewhere else cheaper, but guess what, they are 2 ohms, a direct replacement for the Bose. From other forums, I heard they are awesome.
Here is a direct replacement for the rears,
http://www.crutchfield.com/S-2Fk8Nke....asp?i=108627I
cheaper here, http://www.etronics.com/product.asp?...ore=&catid=358
Also got this info from another site, interesting,
This is if you want different ohm speakers,
If you want to keep your Bose Headunit and replace the amp and speakers, you need this:
http://www.pac-audio.com/oem1kits/ao...or+AOEM-1+kits
If you want to change you Bose headunit and keep your stock amp and speakers, you need this:
http://www.pac-audio.com/oem1kits/ro...or+ROEM-1+kits
You cannot change your speakers and keep the stock amp.
You cannot change the stock amp and keep the stock speakers.
You cannot change the headunit without the above adaptor.
I am seriously thinking of swapping my components and rear coaxial out next year when I return from Korea.
Anyone wanna try this and post the outcome of just replacing the speakers?
Old Feb 25, 2006 | 09:35 AM
NzZ's Avatar
NzZ
Hey guy, can you give me a link to a review of these? I'm just curious b/c the bose system is equalized to compensate for the crappy speakers...I'm not sure how good speakers would sound w/that equalization. If it really is good, this is a phenomenal deal...upgrading the bose to quality sound for less than $300!
NzZ
Old Feb 25, 2006 | 09:36 AM
zand02max's Avatar
zand02max
http://www.*********.com/forums/inde...opic=12882&hl=
insert 3 5 0 t e c h . com
Old Feb 25, 2006 | 12:27 PM
CAN0802's Avatar
CAN0802
I have to call BS on this one, as I changed my Bose head unit without that adapter, and it has been working without a single problem for the past 10 months, and yes, I am still running through the factory amp and speakers.
Old Feb 26, 2006 | 01:14 AM
lololepro's Avatar
lololepro
Would it also be possible to replace the Bose sub without replacing the amp(s)?
Old Mar 6, 2006 | 11:22 AM
[]V[]addog's Avatar
[]V[]addog
I think one of the main problems with that sub is the lack of power going to it and that it;s not in a seal box. Am I correct. (I know it;s not the best sub but I think it would sound better if it was installed liek mentioned above)
kyin
Oct 15, 2015 05:54 AM
