Kenwood DDX-8017 Question
Old Feb 28, 2006 | 08:45 AM
joeun's Avatar
joeun
Default Kenwood DDX-8017 Question
I recently installed my system along with the Kenwood DDX-8017. Now the AM station is not as strong as when the stock unit was on. I need the local sports stations! Have you all run into this problem as well? What can I do to fix this? Thanks everyone...
Old Feb 28, 2006 | 09:02 PM
imalazeeass's Avatar
imalazeeass
got any pics?
Old Feb 28, 2006 | 09:11 PM
jdohman's Avatar
jdohman
AM uses the body of the car for its ground. I would make sure your ground wire is connected very well and that should clear up any problems you may have. If that doesnt work look for a AM booster
Old Feb 28, 2006 | 09:14 PM
Tyler's Avatar
Tyler
did you hook up the power'ed antenna lead? Solid blue wire from the kenwood to the solid blue wire on your harness adptor. The 350 has a "booster" of sorts, like many of the new Honda's, that needs to be powered up to get max signal.
Old Mar 5, 2006 | 08:34 AM
mdboy1213's Avatar
mdboy1213
same here....well i dont listen to am but my fm reception sucks compared to stock
issyz
Jul 2, 2017 03:04 PM
dcains
Nov 11, 2015 11:36 PM
Alexreyes
Sep 30, 2015 11:30 PM
