Component Xovers not in door...
Old Mar 3, 2006 | 11:21 AM
dream724Z's Avatar
dream724Z
Default Component Xovers not in door...
The numerous speaker posts inspired me for new fronts. Thanks guys! I bought speakers with a brilliantly designed crossover. I was concerned their mesh top wouldn't handle door moisture. CDT's friendly customer service confirmed my fear, "do not mount these in the door unless they are completely sealed". Given they have manual cutoff adjustments, it is best to keep them accessible near the amp. I dread running more wire pairs through the door seal, oh well that's the POA.
Old Mar 3, 2006 | 11:43 AM
buzzardmountain's Avatar
buzzardmountain
Mine are mounted behind the drivers seat. The BA crossovers are huge and would've never fitted in the door anyway, not that I would of put them there in the first place. Here's a pic to give you some idea:
Old Mar 3, 2006 | 01:24 PM
dream724Z's Avatar
dream724Z
Nice and clean flush mount! Thank you for the input!
Old Mar 3, 2006 | 02:17 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
running dual wires into the door of a Z shouldnt be bad if you want to make your life easier, pick up 4 channel sepaker wire that is cobined into one single outter loom, much faster and easier...
the space in the molex plugs should allow 6 pairs even to go through no problem
if you have a door grommit pull through tool watchamacall it, lol it will be eaiser, basicall a screw driver htingly with a tube through it, stick one end into the rubber hose, so the sharp metal end comes out the end, and then push wires through, and grab it at the other end and pull out the tool
b
Old Mar 3, 2006 | 02:22 PM
BriA5's Avatar
BriA5
If you don't want to showcase the crossovers, you can always burry them under the floor of the glove box behind the passenger seat.
Pull out the plastic tray in there and secure them underneath. That's where mine are and then they are still accessible, yet out of the way.
Old Mar 3, 2006 | 02:27 PM
GQ 350z's Avatar
GQ 350z
Werd up pick up the 9 conductor speaker wire.
Old Mar 3, 2006 | 02:53 PM
dream724Z's Avatar
dream724Z
Great tips! Now I can route the wire without unplugging the connector (16psibrick). Under the glove box would be perfect (BriA5)! Thanks guys, now I am psyched to do this upgrade with less pain.
9 conductor wire?! It's still better than stock's <22 gauge and made from *7* strands! How much did Nissan save on copper?!
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
jlb
Oct 15, 2017 05:10 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
