Issue with CDA 9853, help!
Old Mar 4, 2006 | 02:56 PM
plumpzz's Avatar
plumpzz
Default Issue with CDA 9853, help!
Hey guys I just got a Alpine CDA 9853 but my tuner isn't working too good.. I'm not getting good reception. Am i supposed to use the tuner wiring? The stock antena wire seemed to fit right in so i didnt...
I'm getting crappy to no reception...
Help would be appreciated with someone who's installed this. Thanks
Old Mar 4, 2006 | 03:10 PM
Dream's Avatar
Dream
See my thread for links + a small summary of the antenna amplifier hookup.
Old Mar 4, 2006 | 03:23 PM
plumpzz's Avatar
plumpzz
Wait, so the plug doesn't work alone? I have an plug kit...so would i still conneect POWER ANT to green with white stripes?
Old Mar 4, 2006 | 08:37 PM
plumpzz's Avatar
plumpzz
Some help would be appreciated
I connected POWER ANT to AMP TURN ON...still not working..
Old Mar 4, 2006 | 09:15 PM
Trip's Avatar
Trip
As per the thread linked three posts above: The green wire with the white stripe (the antenna amp wire) on the factory harness should line up with the blue wire on the aftermarket harness. (*edit* if you have a kit, connect the p/ant wire from the alpine unit to the wire in the harness that corresponds to the grn/wht wire in the manuf. harness. Should be blue wire if you are using the Metra harness)
You can take his word on this, it's a common beginner install mistake. You need to hook up the power antenna wire on most nissans. Though I am an experienced installer, I made the same mistake. When I see a nissan that has no power antenna nor neccessitate an antenna conversion harness, I normally don't hook up the p. ant. wire. Quickly realised my mistake upon testing the fm tuner after install.
BTW, Alpine uses a blue wire for p. ant. and a blue/white wire for amp turn-on. If your amp only turns on with the radio, you got them backward
Old Mar 4, 2006 | 10:16 PM
plumpzz's Avatar
plumpzz
ahh... i realized that alpine uses a blue wire for for p ant and a blue white wire for amp turn on... i connected blue white-blue white and blue to blue and it works now.. Someone told me not to connect blue to blue or blue wite to blue white since i dont have an amp -.-
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
