integrating lcd screen into cubby hole
Old Apr 8, 2006 | 03:37 PM
ESPO 774's Avatar
ESPO 774
is it possible to transfer the skin off of an 06 cubby door onto an 03, so that it matches the console??? thanks
Old Apr 9, 2006 | 01:14 AM
gt3's Avatar
gt3
Originally Posted by visionboy
how do you swap the skin? Just peel both of them off and switch them? details please.
+1 I have looked at the skin and it did not seem that easy to replace it. Any info would be appreciated!!!
Old Oct 4, 2006 | 10:42 PM
JohnnyDigital's Avatar
JohnnyDigital
Any updates on swapping the skins?? Are there any threads of someone successfully doing it?
Old Oct 5, 2006 | 06:12 AM
Voboy's Avatar
Voboy
Originally Posted by ESPO 774
will the 03 cubby door fit in an 06? and will the skins transfer??
You shouldn't be worrying about that. The 03 Cubby doesnt even have the right holes for screw alignment to fit the 06. That's why there's an 06 cubby that matches perfectly. But not to sure about the nav finisher, and I don't beleive anyone has gotten the nav door working properly yet. I know evobunny is working on this i think...he has the 06 cubby, not too sure if he's gotten the door to operate yet.
Old Oct 5, 2006 | 12:09 PM
evobunny's Avatar
evobunny
sorry voboy I didnt get the door to work. I just didnt bother with it. its not really a big deal for me to have it up. it just something less to break. my brother who has a computer electronic degree said it wouldnt be hard to make a chip to make it open and close. but you would have to buy one of those chip building kits which cost a bit.. like maybe under 100. so I wasnt worry about it. someone on here makes the chip and sell them. but I remember it being very expense. so I was like forget it.
Old Oct 5, 2006 | 01:18 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I re skinned the 03 cubby with my 04.5 door.
The doors are the same size and shape but the back of the door is different enough to cause problems for people not used to winging it.
For the lower part, I took the back frame off, cut it across the center so I could use the lower half with the latch.
For the top I used a small strip of steel that I bent and riveted to the metal part of the lid door. This attached to the spring that pulls the door up. This part was probably the most difficult. It has to be aligned perfectly or it will pull on the door at an angle and cause it not to go up.
Here are the pics I took when I did it a while back. The ugly plastic melting is how I got the lid reattached to the metal frame.
Chris
Old Oct 5, 2006 | 04:59 PM
minispider's Avatar
minispider
Originally Posted by StifflerHB
what about this display ? click
It looks exactly like the Farenheit. Same size ?
is the same screen...I got one from ebay 2 weeks ago $100, looks beautiful
Old Oct 5, 2006 | 10:24 PM
CG 350Z's Avatar
CG 350Z
Does anyone know if someplace like courtesy parts or some other site sells the 03 cubby?
Old Oct 6, 2006 | 06:39 AM
HyperSprite
Mad Scientist
mynismo.com is where I got mine.
Chris
Old Oct 6, 2006 | 05:51 PM
babyit11's Avatar
babyit11
this question may have been asked already, but i didn't see it.
do you guys know if i would be able to do this on my 2006 Z?
I would like to add a screen as well
Old Oct 6, 2006 | 06:06 PM
bdahern's Avatar
bdahern
+1
Old Oct 6, 2006 | 06:34 PM
minispider's Avatar
minispider
yes it can be done on an '06, did not buy anything just a little dremel and that was it.
[IMG][/IMG]
Old Oct 6, 2006 | 06:51 PM
RockerNJ's Avatar
RockerNJ
Details please? Is that the factory pocket with the back dremeled out?
Old Oct 6, 2006 | 07:18 PM
minispider's Avatar
minispider
no, just a cut about 1/2 inch wide and the screen was slit underneath.
You do have to remove the plastic frame from around the screen, a little fiddleling with it in the cubbyand that's it, the cubby still intact in the back. The rubber mat just have to be cut, so what you see in the pic is just the front piece, a hole in the back for the rca video and power wires and that's it. The door still closes, I secured the monitor with a small plate under the cubby so if won't fall down. It looks perfect. and better yet no $ was spent
Old Oct 6, 2006 | 07:23 PM
minispider's Avatar
minispider
[IMG][/IMG]
Old Oct 6, 2006 | 07:24 PM
filanj's Avatar
filanj
nice mod
Old Oct 6, 2006 | 11:04 PM
cruZin163's Avatar
cruZin163
Very clean. What kind of LCD did you use?
Old Oct 7, 2006 | 05:48 AM
  #38
RockerNJ's Avatar
RockerNJ
Seconding the "what screen is it". I have a Lilliput 619GL (7") that I'd like to install. Looking at what you did, this just may be the method I've been waiting for.
Old Oct 7, 2006 | 10:37 AM
  #39
minispider's Avatar
minispider
the screen is a farenheit, and yes is just a slit about 1/2" wide, the screen sits on the hinges (on top), also you need to dremel the inner upper cover edge so when you close it doesn't hit the top of the screen.
Old Oct 7, 2006 | 10:45 AM
  #40
babyit11's Avatar
babyit11
[IMG][/IMG]
kool, thats wat i wanted to know. one i get the funds i will buy a 7in screen and do this mod myself.
