5 Channel amp question???
I've got a Pioneer headunit, 4 aftermarket speakers and a 10"sub and a 5 channel amp. I want to run all the speakers and the sub off the amp. The headunit has a front, rear and sub preout. My question: If I'm going to run them all off the amp, which preout on the headunit do I connect the amp to, front, rear or sub? Everythings compatible, the amp is powerful enough to run everything and all ohm loads are compatible with the amp. Thanks for the help,
Derek
Derek
