How Do I Construct A Sub Box In The Stock Location?
Old May 4, 2006 | 05:05 AM
  #41
03zsmith25's Avatar
03zsmith25
lets get some pics!!!!!!!!!!!!!!!!!!!!
Old May 6, 2006 | 08:49 AM
  #42
BadBlood's Avatar
BadBlood
Based on this thread and others, I started making a new design. I finished the basic construction, and it seems to fit without issue albiet -very- snug front to back.. There's another thread started to get feedback on it, but I figued you guys may be interested for sure.. Here's a diagram.
Old May 9, 2006 | 10:59 AM
  #43
sorphin's Avatar
sorphin
looks interesting but i can't quite picture it as easy as the other box was to picture (and i'm a visual person )
Old Jun 11, 2006 | 05:07 PM
  #44
ZWildZ's Avatar
ZWildZ
Hey, GuyK -
Do you have a db rating on the setup you're running? It's just that on man's "loud" is another man's "what, I can't hear it". Also, have you heard one of Mike's under-strutbar boxes? How does it compare?
Thanks!
Chuck
Old Jun 12, 2006 | 07:42 PM
  #45
guyk's Avatar
guyk
Originally Posted by ZWildZ
Hey, GuyK -
Thanks!
Chuck
No db rating Chuck and I havent heard one of the under strutbar boxes so I cant comment. Sorry!
Old Jun 21, 2006 | 05:59 PM
  #46
blazersman's Avatar
blazersman
Default success!!
Originally Posted by camaro194
I just wanted to thanks for all input on this thread. After searching and analyzing how I wanted to go about getting some bass in my Z, I decided on this route. Finished the box this afternoon, stuck a RF P2 10" sub in there, ran it with a low powered amp, and got exactly what I was looking for. I recommend this design for anyone looking for an "adequate" amount of bass, who is considering weight as well as the stealth look. All in all, I'm very pleased!!! Thanks guys!!!
Old Jun 21, 2006 | 06:07 PM
  #47
BigZ88's Avatar
BigZ88
so is that an up facing sub? how exactly does this fit in the stock location? i would have expected it to be flipped over....can you take pics of it in your car? does this box fit EXACTLY in there or is there room around it still? I'd like to re-arrange the design a bit for 2 6" subs if possible
Old Jun 22, 2006 | 06:57 AM
  #48
blazersman's Avatar
blazersman
No... it faces down, it is flipped over from the picture. I can take pictures of it in the car if you'd like. PM me in a few days if you don't here from me... I have a bad memory!!! If I had to do it over again, I would make it a little less long... so maybe 15" instead of 16 long... and then it could become wider... so maybe 17" instead of 15.5" wide. Let me know if I can help!!!
Old Jun 22, 2006 | 10:49 AM
  #49
DesiZ_06's Avatar
DesiZ_06
ya post the picture..i wanna see how it is in the car.
Old Jun 22, 2006 | 11:18 AM
  #50
ralphpolanco's Avatar
ralphpolanco
Default I wanna see toooooo
I saw where someone asked the questions, can you install the box from just the stock sub cut out access?
I did see where there was a response.
I really don't want to tear into the rear, so if this box cannot be installed through the bose sub access then I'm going with a powered type sub like a Bozoka or any that you guys recommend.
Thanks
Old Jun 22, 2006 | 01:59 PM
  #51
blazersman's Avatar
blazersman
Thanks
The only thing you have to take out to get the sub box above in the car is the metal plate that the stock sub is bolted onto. It is just bolted on the frame, so there's really no "tearing into the rear" involved. Hope this helped... and I will post pics asap!
Old Jun 28, 2006 | 09:18 PM
  #52
MI 35th's Avatar
MI 35th
OGPremierMafia
subscribing for pics!
Old Jul 15, 2006 | 06:31 PM
  #53
NH350Z's Avatar
NH350Z
pics are always good
Old Jul 16, 2006 | 08:30 AM
  #54
blazersman's Avatar
blazersman
Default pic
sorry it took so long... i've been totally bummed out with my sound system... a week after i got it all up and running, my avic N1 went out on me, so i had to pull everything out! very frustrating!!
Attached Thumbnails How Do I Construct A Sub Box In The Stock Location?-small.jpg
Old Jul 16, 2006 | 11:05 AM
  #55
BigZ88's Avatar
BigZ88
wow that doesnt fit in there very well at all. Looks like it would slide around while driving, and where does the sub sit?.... i'm not a big fan.
Old Jul 16, 2006 | 01:37 PM
  #56
blazersman's Avatar
blazersman
Like I said above, the sub fires downward. From the picture, it does seem like it would slide around, but it doesn't. You can bolt it down pretty easy in the back. I've also seen people simply tie it down, but I haven't had any sliding issues at all.
Old Jul 17, 2006 | 09:50 AM
  #57
HockeyZ39's Avatar
HockeyZ39
Sweet, I will be trading my rear hatch box in for one of these once I get around to building it. Sick of my trunk space being taken up, and every one being able to see I have upgraded audio.
Old Jul 21, 2006 | 01:07 PM
  #58
HockeyZ39's Avatar
HockeyZ39
In this pic are they using two 5/8 MDF pieces together for each side?
Old Jul 21, 2006 | 03:55 PM
  #59
blazersman's Avatar
blazersman
No
Old Sep 22, 2008 | 04:35 AM
  #60
PabloZ's Avatar
PabloZ
Default Further clarification
blazersman,
Could you give some more info on if / how you secured the box & sub from moving around?
Did you Dynamat the stock cavity?
Will the stock Bose cover fit with the box as shown, and I'm also wondering if that cover will rattle - since it doesn't seem very tight.
thanks...Pablo'Z
