Kenwood Excelon Amplifier and System Specials FULL SYSTEM UNDER $670
Old Mar 28, 2006 | 03:40 PM
Nazar's Avatar
Nazar
Default Kenwood Excelon Amplifier and System Specials FULL SYSTEM UNDER $669.95
Here is a special we are offering for those in need for a nice clean amplifier and possibly a full system without spending an arm and a leg.
Simple buy two of the new Excelon amps $415 + Components for $139.95 + a Sub for $115 = $669.95 Just add a deck or hook up to stock deck. You have a Nice HI-END system at a LOW LOW Price...
Quantities limited first come first served.
You can purchase them seperately or as a package.
Kenwood Excelon KAC-X812D Sub Amp Retail $450-499
Special $225 + Shipping
Specs Class D amplifier circuit
AMS amplifier management circuit
Variable low pass filter 50hz-200hz
infrasonic filter @ 15 or 35 hz 24 db per octave
Adjustable frequency bass boost circuit
Bass Q factor control
Bass level control
Variable band reject filter
1 ohm stable
Gold plated in / out terminals
2 Speed cooling fan
Detachable aluminum cover plates
Die cast aluminum heat sink
1 ohm stable
Toroid noise suppression
Copper EE core power transformer
1 x 533 Watts RMS @ 4 ohms CEA-2006 rating
1 x 919 Watts RMS @ 2 ohms CEA-2006 rating
MATCHING 2 CHANNEL
Kenwood Excelon KAC-X522 Retail $350-400
SPECIAL $195 + Shipping
SPECS
2 Channel amp
Variable low pass/High pass filter 50hz-200hz 12/24 db per octave
Adjustable treble frequency control
Bass level control
2 ohm stable
2 Speed cooling fan
1 ohm stable
0.5% THD @ rated output
2 x 165 Watts RMS @ 4 ohms CEA-2006 rating
4 x 254 Watts RMS @ 2 ohms CEA-2006 rating
BUY BOTH SUB AMP AND 2 CHANNEL FOR $415 SHIPPED MEMBERS ONLY. ONLY 3 SETS AT THIS PRICE, CREDITCARDS OR PAYPAL WELCOME.
SHIPPING EXCLUDES HAWAII, CANADA, ALASKA.
I also have XXV-02A 4 Channel AMP 25th Anniversary Model
THIS IS TRULY A GREAT AMP.
Special $265 + Shipping Only 2 at this Price [/COLOR]
4-channel car amplifier
88 watts RMS x 4 at 4 ohms (124 watts RMS x 4 at 2 ohms)
240 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
variable high- and low-pass filters (50-200 Hz, 24 dB/octave low-pass, 12 dB/octave high-pass)
subsonic filter for rear channels (0/15 Hz, 24 dB/octave)
AMS (Amplifier Management System): -15 to 15 dB bass level control, Q factor control, bass/treble frequency control
aluminum electrolytic capacitors
high-speed Linear Amplitude Power Transistors (LAPT)
cooling fan
LED status display (voltage, current, temperature, fan speed)
CEA-2006 compliant
preamp outputs
Tri-way capable (Tri-Way Crossover required)
2-, 3-, or 4-channel output
fuse rating: 30A x 2
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
Also 1 Left Matching 25th Anniversary Subwoofer Amplifier
XXV-03A SUB AMP $265 + Shipping[/COLOR][/B]
25th Anniversary Super Filtering Capacitors for Special Sound Tunning
High Quality Glass Epoxy PCB
Blue LED Display
Amp Control System
Amp Information Display(Voltage/Current/Temperature/Cooling Fan Speed)
Cooling Fan (Computer Controlled)
Detachable Aluminum Dress Plate & Top Panel Control
Gold Plated RCA Line Input/Output Terminals
D-class Amplifier Circuit
1 ohm Load Capability
Built in Parametric EQ Control(Bass Frequency/Gain Control/Bass Q Factor)
1600 Watts MAX Power
1 x 400 Watts RMS @ 4 OHM
1 x 800 Watts RMS @ 2 OHM
1 x 1000 Watts RMS @ 1 OHM
Tested at 14.4v.
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct)
Built-in Infrasonic Filter 15Hz/25Hz (24dB/oct)
Phase Inverter (0°/-180°)
Band Reject Filter Frequency 6dB/12dB (40-200Hz Variable)
Power MOSFET
Power Supply Fuse : 25A x 3
BUY BOTH 25th ANNIVERSARY SUB AMP AND A 4 CHANNEL AMP
$500 SHIPPED
KENWOOD eXcelon KFC-X1700P 6.5" COMPONENTS for only $139.95 With purchase of an Amplifier. Shipping included with amp.
Features:
6.5/6.75" Mid
Impedance 4 Ohms
25 mm Soft Dome Tweeter
Peak Power 220 Watts
Rated Power 55 Watts
Frequency Response 35 Hz - 30,000 Hz
Sensitivity 92 dB
Crossover Frequency 3,200 Hz
KFC-XW1002DVC 10" Subwoofers with purchase of a Sub amp $115 Shipped with amp.
1000w Max Power
Dual 2 ohm Voice Coils
250w RMS
91dB Sensitivity
5 5/16" Mounting Depth
Butyl Rubber Surround
Carbon Hybrid Cone
50Hz-400Hz Freq Response
Wire into a 1ohm or 4ohm load
Cast Aluminum Basket
Voice Coil Jumper Cable Included
Old Apr 9, 2006 | 06:59 AM
Nazar's Avatar
Nazar
You can mix and match in any ways you want and get free shipping.
sales@czp
Sep 23, 2019 03:30 PM
_bit
Oct 2, 2015 07:49 AM
