hi/lo converter problems
Old Mar 30, 2006 | 06:16 PM
myturbo350z's Avatar
myturbo350z
Default hi/lo converter problems
I just put a system in my car, and all the wires are hooked up right, and i put the hi/lo converter to a speaker, and it didnt work, so i moved on and tryed to put it to the sub, and it still didnt work, I dont get what the heck is up because its not getting any signal in the RCAs from the speakers. could it be because everythings amplified stock?
any idea whats up?
Old Mar 31, 2006 | 09:38 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
something isnt right... make sure you have the right wires tapped
Old Apr 2, 2006 | 04:27 PM
myturbo350z
i do have the wires correct, ive done installs in over 10 of my friends cars and never once has this happened, untill ive done it on my own car.
Old Apr 2, 2006 | 04:35 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
I had this happen when I installed a system in a 350z... some of the wires were not what my service manual said they were...
Beware... If you have a DMM. Check and make sure their is voltage going through the wire you tapped...
Old Apr 2, 2006 | 04:38 PM
myturbo350z
the thing I dont get, is the amp is one, and when i go to tapp the hi/lo converter into a speaker, it doesnt send any signal to the amp, but when i plug the speaker back in, the speaker works.
Old Apr 2, 2006 | 04:44 PM
momo 350z's Avatar
momo 350z
maybe the converter is bad...
Old Apr 2, 2006 | 04:52 PM
myturbo350z
ive tried 2 different ones now.. so i doubt its that.
Old Apr 2, 2006 | 05:05 PM
slacker's Avatar
slacker
If it is bose you have to bypass that signal you can't just Tap the wires. If not try to get your signal right behind the speaker if it is out just to check it. if still nothing check your wiring might be bad ground, bad amp, or pinched wire. Because if u tried three conv that is not the problem.
Old Apr 3, 2006 | 07:43 PM
myturbo350z
how do you bypass the signal?? i figured itd have something to do with it being bose
Old Apr 3, 2006 | 08:05 PM
myturbo350z
maybe i should have mentioned i have an 03 touring..
Old Apr 4, 2006 | 04:18 PM
slacker's Avatar
slacker
Try this they should have what you need.
http://www.linkmeup.com/
from my experience bose is not fun to upgrade... almost easier to replace head unit and run new wires to all the speakers. Hope it helps
Old Apr 10, 2006 | 07:48 PM
myturbo350z
dang, looks like im buying a head unit.. haha
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
