Wire Locations
Old Apr 8, 2006 | 05:31 PM
UrbanTacticZ's Avatar
UrbanTacticZ
Default Wire Locations
I plan to wire up my Apexi Rev/Speed meter tomorrow and in the instructions it states I need to locate the Engine RPM wire and the IG Power wire.
Anyone know where I can locate these wires?
Also, what exactly is the "IG Power" wire? Is that IGNITION Power?
Thanks!
Old Apr 8, 2006 | 08:58 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
That orange box has the RPM wire running to it - white color code with light gray rings (NOT STIPES!) in the center connector.
Don't know what in IG is ... ignition is my guess but then I can spell.
Old Apr 8, 2006 | 10:42 PM
UrbanTacticZ
Do you happen to know where I can locate a Speed Input wire?
If the speed input wire is at the ECU, which wire is over there that I can tap into for the RPM input?
The reason why I ask is I want to run the harness for my Apexi unit to one location where I can tap into both wires at once instead of extending wire back and forth under the dash (from the HVAC unit to ECU, etc.)
Thanks!
Old Apr 9, 2006 | 09:50 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
speed input wire is on that white box with the RPM running to it also
I dont know the wire code but I think it is the blue and white wire.
Old Apr 9, 2006 | 09:55 AM
jdohman's Avatar
jdohman
12volts
white/blue
ignition harness
Starter white/red + ignition harness
Second Starter white/green + ignition harness
Ignition black/red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory white/black + ignition harness
Second Accessory N/A
Keysense black/red + ignition harness
Power Lock red - driver door module in door
Power Unlock lt. blue (double pulse) - driver door module in door
Lock Motor purple 5wi white plug, pin 30 at BCM
Unlock Motor yellow 5wi white plug, pin 23 at BCM
Parking Lights+ red/blue + driver kick panel
Parking Lights- N/A
Hazards green/red - brown plug, pin 61 at BCM
Turn Signal(L) green/white + white plug, pin 22 at BCM
Turn Signal(R) purple/white + white plug, pin 21 at BCM
Reverse Light lt. green + driver kick panel
Door Trigger white (L), pink (R) - white plug, pin 14, 10 at BCM
Dome Supervision comes on with unlock
Trunk/Hatch Pin red/white - white plug, pin 18 at BCM
Hood Pin lt. green/black - hood pin switch under hood
Trunk/Hatch Release pink - brown plug, pin 76 at BCM
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT white/blue or black ac any ignition coil
Wait to start N/A
Brake Wire pink/blue + brake pedal switch
Parking Brake purple - parking brake switch
Horn Trigger green/black - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Old Apr 9, 2006 | 01:43 PM
UrbanTacticZ
Anyone know what color the Speed wire is for sure? I'm not tryign to blowup my Apexi Rev/Speed meter
Old Apr 9, 2006 | 02:30 PM
UrbanTacticZ
Found the wire, just took a little digging on the forums:
https://my350z.com/forum/showthread....eed+pulse+wire
It was a white wire, #26
Old Apr 9, 2006 | 03:48 PM
UrbanTacticZ
Also Paul, I think I became confused because you have an 05 and I have an 03. The wire colors and pinout's differ. Check the attached pinout from my 03 service manual.
I don't even have a pin #20 on the center plug
On the 03 it is pinout #26 and the wire is a solid white wire with a pink band on it
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
