New Convertible / Coupe Sub Box Behind The Seats
Old Aug 9, 2006 | 12:53 PM
  #81
16psibrick's Avatar
16psibrick
Simplicity in Sound
not close on either, too deep
Old Nov 29, 2006 | 01:41 PM
  #82
Nazar's Avatar
Nazar
I have a new Memphis 10" Power reference series that will work in this enclosure.
Old Mar 5, 2007 | 03:27 PM
  #83
Nazar's Avatar
Nazar
These boxes are now making a come back just wnated to remind everyone these are still available.
AND YOU CAN SEE PICTURES AT
http://www.wickedcas.com/gallery/mai...cboxes/ZR350Z/
Old Mar 5, 2007 | 05:05 PM
  #84
ermartin's Avatar
ermartin
will it work with the Kicker CompVT 07CVT122 looks like it needs 4,5 inches but will box volume bo ok as well here is the link.. also Any opinions on this speaker http://www.crutchfield.com/S-IeBVr9Q...0&I=2067C12VT2
Old Mar 5, 2007 | 05:07 PM
  #85
Nazar's Avatar
Nazar
You will need a 10"
Old Nov 7, 2007 | 03:21 PM
  #86
Nazar's Avatar
Nazar
We are working on a new design to accomodate a slightly bigger sub, Up to a w3v3.
Old Nov 21, 2007 | 06:29 AM
  #87
Nazar's Avatar
Nazar
Unfortunately we have to make a price adjustment on these boxes. With th ecost of just about everythng going up we are now paying more for material.
New price will be $319.95.
Old Dec 16, 2007 | 08:01 AM
  #88
RollingRocker's Avatar
RollingRocker
Smart @$$
Lightbulb Any luck on JL 10W3 in Glove Box Enclosure
Are you having any luck on modifying the glove box enclosure for the350z to work with the JL 10w3v3. I’m putting a lot of planning into my install and I don’t want the subs to be the weakest link. I have seen an awesome install where they used 2 JL 8W7s behind the seats in ported enclosures. They fired forward of course and it looked awesome I just wish I could hear it. The Specs on the 8w7 call for a sealed box of 0.875 cu. ft. or ported at 1.0 cu. ft. It also looks like the 10W6v2 would work in this box in a front firing configuration. It’s specs call for 0.625 cu. ft. and it has displacement of 0.068 cu. ft. so that would work perfect. I would actually like to show off my subs instead of tucking them away. I’ve seen a few posts on the internet where guys have build mdf boxes for behind the seats and I could always do that but I see no point in reinventing the wheel. Would it be possible to modify your enclosures to work with 10w6v2 in a front firing mode. If so what would something like that cost.
Old Dec 29, 2007 | 12:15 PM
  #89
Nazar's Avatar
Nazar
We are working on a new design, I don't expect it to be done for at least a month or so.
I need a stock glove box if someone wants to send it to me.
Old Dec 29, 2007 | 09:49 PM
  #90
BakaN20's Avatar
BakaN20
Can you give any details on what your new design will be like? I think I got one of your earlier models from one of the members here. I wish I could put the box in the trunk, makes a big difference compared to behind the driver seat, but I like to keep my trunk space and even though it probably does nothing, but keep my weight distribution stockish, lol. Love the box though, keep up the great work!
Old Dec 30, 2007 | 05:57 AM
  #91
Nazar's Avatar
Nazar
Ourgoal with the new design will be to acomodate for a deeper sub. Deeper mounting depth. Atleast for a 10w3.
Old Dec 30, 2007 | 08:38 AM
  #92
MethodRN's Avatar
MethodRN
For Sale
Would a sub with the following specifications work w/ this enclosure
Power Handling RMS/Peak
300/1200
Suspension
50 mm
Nominal Impedance
4.0 Ohm
DC Resistance
3.4 Ohm
Rec Box (cubic ft)
1.5
Port Area (sq in)
22
Port Length (inches)
16
Woofer Diameter
10"
Free Air Resonance
38 Hz
Qts
0.405
Qes
0.461
Qms
3.29
Vas
23
Sensitivity
86.5 dB
Mounting Depth
5.0625"
Occupied Volume
0.113
Old Dec 30, 2007 | 10:36 AM
  #93
KManZ's Avatar
KManZ
I really want this enclosure so as to not use up my limited trunk space on a sub, even though it won't sound as good. I don't want super huge bass, just enough to accentuate my components.
Old Jan 15, 2008 | 06:32 PM
  #94
RollingRocker
Smart @$$
Any luck on the new design. I'm ready to order as soon as you've got it together.
Old Jan 16, 2008 | 05:39 AM
  #95
Nazar's Avatar
Nazar
New enclosure will be a while.
MethodRN,
It sound like it will fit, But my enclosure is Sealed.
KManZ
This was designed for the space concious driver, It has tons more bass then the stock system, But will not compare to the strut tower enclosures.
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
