Need some help - blew a fuse maybe more?
Old Apr 28, 2006 | 12:13 PM
ckny's Avatar
ckny
Default Need some help - blew a fuse maybe more?
Well I was messing around with a radio install and I believe that I might have reversed the polarity when tapping into the yellow (+12v continuous) and blacck (ground) wires coming from the radio harness. I blew out a fuse that conrolled the lighting on the guages and I thought the radio. I replaced the fuse and I have my gauge lighting back but still no power from the battery or ground.
So right now it appears everything else works correctly but I do not have ground or continuous 12 volt (black and yellow wires from radio harness). I do get accessory power (red).
Any ideas? I suppose I can run a new wire from the battery but is there something easier that I might have overlooked? Is there potentially anything else affected?
Thanks!
Old Apr 30, 2006 | 12:27 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Yikes!
You measured ground using an ohm meter and aren't reading ground?
Or
Did you measure between the yellow and black wires with a volt meter and aren't reading a positive 12 volts?
Or
Both?
I'd be willing to bet number 2 - that the ground wire is still functional and you've lost +12 VDC. It's very rare that you'd blow two fuses in series with each other - like I've never heard it done before - but I suppose that it is possible.
The J/B Fuse box (next to the driver's left foot) 15 amp fuse number 6 provides ignition controlled accessory power and on a blue with green stripe wire doesn't feed the triple gauge (red w/white) according to the schematic on page PG 4 of the service manual. It looks like they're fed from 10 amp fuse 19.
Both fuses 17 and 19's circuits are fed from a sub-master 60 amp circuit breaker D.
Battery power is fed from 15 amp fuse 37 located in the fusible link box (under the hood in front of the battery) on a yellow wire. It feeds "DI Clock, AV Audio, and AV Navi" circuits per the manual and not the "DI 3Meter".
Ground is a pain ... I don't want to go there unless I have to! Get back to me in the thread if you have a good fuse 37.
(all colors are Nissan factory Bose colors)
350Z Project X
Oct 17, 2015 05:16 PM
kyin
Oct 15, 2015 05:54 AM
FromGtoZ
Sep 20, 2015 03:41 PM
Beater350z
Sep 9, 2015 03:36 PM
AP350z223
Sep 8, 2015 04:38 PM
