Question about cig lighter cables...
Old May 5, 2006 | 05:24 AM
mandm177's Avatar
mandm177
Default Question about cig lighter cables...
In order to power my dvd player, it came with a cig lighter adapter...instead of plugging that in, is it possible to just cut the cable, and splice that into a 12v source?
Old May 5, 2006 | 05:31 AM
sq40's Avatar
sq40
Most of the Time Yes, As long as there are no electronics in the adapter itself to control voltage/amperage you should be fine.
Old May 5, 2006 | 05:52 AM
mandm177's Avatar
mandm177
thank you sir, thats the answer i was looking for. im assuming that i dont have to worry about a ground or anything, correct?
Old May 5, 2006 | 05:53 AM
sq40's Avatar
sq40
Yes, you have to have a ground, the Sides of the Plug are the Ground and the Tip is 12v+. Just open the plug up and see which wire goes where.
Old May 5, 2006 | 11:27 AM
XtaZee's Avatar
XtaZee
You want to add a fuse in order to protect it from surges. Napa sells a product called Mini -Add-a-Circuit.-
This allows easy installation of additional circuits without cutting or splicing. Turns one fuse slot into two while providing protection for both circuits. Which is alot better protection than simply splicing into a 12v source.
Old May 30, 2006 | 04:00 AM
juan_amarro's Avatar
juan_amarro
What is the best way to get at the rear cig. lighter? Do you have to remove the entire rear panel or is there another way?
Old May 30, 2006 | 05:21 AM
mandm177's Avatar
mandm177
you can actually pop the rear cig lighter out. just get a flathead and start prying the sides to pop it out.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
