jl 10w3v3 in stealthbox ...pics...
Old May 9, 2006 | 10:04 AM
rx7/350z's Avatar
rx7/350z
Default jl 10w3v3 in stealthbox ...pics...
i just installed 2 10w3v3-4ohm subs in a stealthbox with an excelon x811d amp. I love bass and i usually max out my sub amps power all the time , but not with these. these subs POUND in the stealth box. I highly reccomend.
sorry i didn't vaccum and clean after install
had to add a pic of the plate again
Old May 9, 2006 | 11:20 AM
drifter23's Avatar
drifter23
How many watts are you running to the subs? I should be getting my stealthbox by this week and your setup looks sweet. Any additional modifications needed to fit those subs in the stealthbox? Thanks in advance.
Old May 9, 2006 | 09:59 PM
rx7/350z's Avatar
rx7/350z
they fit perfect and my amp is 919rms wired to 2 ohm (parallel)
rx7/350z's Avatar
rx7/350z
Old May 10, 2006 | 03:24 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
haha the gain on your amp is not a volume ****. How high you turn it up is relative to the input signal from your deck.
If you have a high input signal, your gains are low. If your input signal is low, your gains are high. The only way to know what the amp is doing is with a multimeter and an o-scope. Or with a 60hz test tone, an accurate birth sheet, and a dmm.
Old May 10, 2006 | 07:13 AM
rx7/350z's Avatar
rx7/350z
well the amp has a digital readout on top that shows an instantanious amperage draw.
1sentra
Nov 23, 2007 07:25 PM
stossie
Dec 25, 2006 08:28 PM
