Amp and Sub install last minute items
Old May 9, 2006 | 07:50 PM
StillAlive2029's Avatar
StillAlive2029
Default Amp and Sub install last minute items
ok so i bought Infinity 6010 CS speakers and installed them in stock door area with the stock wireing and amp... i then bought a sub enclosure, a 1052 w 10 inch sub with 250 watts RMS and 1000 peak watts, i also bought the Infinity 7541 a 4 channel 656 watts max power with 111W RMS x4...i also bought a 4 GA grounding kit and a 4 GA power kit with fuse...now along with RCA cables, what else do i need to buy if i plan on just power the sub through the box...also how about if i want to use stock speaker wire and wire my speakers into the amp???what would i need then??
by the way...the search function is not working so sorry i couldnt look this up
thanks a lot
Old May 9, 2006 | 10:05 PM
rx7/350z's Avatar
rx7/350z
run new wires to where the front speakers from the amp. all you need is a power cable with fuse, a ground cable, 2 sets or rca's, a remote turnon wire from the deck or power antenna connection. wire the front two subs to the front connections on amp and bridge(a positive from left and a negative from the right) the back two channels to the sub .
Old May 9, 2006 | 10:06 PM
rx7/350z's Avatar
rx7/350z
as long as the sub has a 4 ohm voilc coil
Old May 10, 2006 | 04:30 AM
StillAlive2029
yea it has dual 4 ohm voice coils
Old May 10, 2006 | 04:58 AM
03zsmith25's Avatar
03zsmith25
make sure ur amp is cool running 2 ohms all the time
Old May 10, 2006 | 06:34 AM
StillAlive2029
yea it says it is fine running 2 ohms
Old May 10, 2006 | 07:14 AM
rx7/350z's Avatar
rx7/350z
yea but not 2 ohms bridged..... just wire it like i said
sales@czp
Sep 23, 2019 03:30 PM
