HELP: CD jammed in OEM stereo
Old May 20, 2006 | 12:47 PM
ac8024's Avatar
ac8024
Default HELP: CD jammed in OEM stereo
My "linkin park" cd is jammed inside my 04 350z OEM stereo head unit. The radio works both FM/AM, however the CD cannot eject or play any music. When I press eject, it sounds like the CD is skipping, and doesn't want to come out. Would appreciate any suggestions, otherwise I will have to buy a aftermarket head unit.
Old May 20, 2006 | 12:56 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
try putting in another cd while its in there. when i had alpine cd got stuck so i just got another cd and tried to push it in. the cd just came out.
Old May 20, 2006 | 02:44 PM
rx7/350z's Avatar
rx7/350z
get a big hammer and a wonderbar
Old May 20, 2006 | 03:36 PM
plumpzz's Avatar
plumpzz
If you still have teh warranty take it to teh stealership. Try the 2nd CD method..most CD players have a sensor which spits out a cd if it isn't in correctly, and having a 2nd CD there simulates that. Itll also tell you if the motor is broken or the button.
Old May 20, 2006 | 07:49 PM
rx7/350z's Avatar
rx7/350z
did the cd u put in have a thick label on it ? that happened to me with the stock deck . i used a pair of needle nose pliars. i kept hitting eject and pulled very lightly on the cd
Old May 21, 2006 | 01:03 AM
onebadfyvo's Avatar
onebadfyvo
Mine is doing (or not doing) the same thing. Though the CD plays, everytime I press the eject button, all it does is click numerous times. I'll try the 2nd CD method. My patience lacks, so if I use needle nose pliers, I'll probably end up stabbing the damn deck.
Old May 21, 2006 | 01:10 AM
erichonghy's Avatar
erichonghy
Unfortunately my CD player won't play any of my CDs. It says "check disc" everytime. sigh...
Old May 21, 2006 | 04:52 AM
SungNamZ's Avatar
SungNamZ
Unfortunately, you will have to visit your dealer. They should order you another unit. Upon receipt of the replacement unit they will remove/replace your bad unit. They are not authorized to disassembly the CD player. It will be shipped back to Nissan/Clarion, where your CD's will be removed and returned to your dealer/you. Happened to me three times and then I woke up and replaced HU with Eclipse AVX2494.
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
