tweeter input wire?
Old May 28, 2006 | 03:41 PM
350ztoronto's Avatar
350ztoronto
Default tweeter input wire?
does anyone know where the stock tweeter input wire is? i wire my headunit to the factory harness and i used what was once the stock tweeter plug as my input wire and that gave me nothing then i used the stock speaker wire as well and that gave me nothing however when i put the headunits wire to the tweeter they work anyone know what im doing wrong?
Old May 28, 2006 | 04:02 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
uh Just wire your head unit into the stock wiring and it should work...
the tweeter splits off in the door.
Old May 28, 2006 | 04:03 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The front door and tweeter speakers are wired in parallel inside the door.
Old May 29, 2006 | 04:21 PM
350ztoronto
i tapped into what used to plug into the stock tweeter and speaker nothing came out, is that the right wires?
Old May 30, 2006 | 01:07 AM
350ztoronto
forgot to add that its a bose system i know the wiring on those are complicated anyone know? help.....
Old May 30, 2006 | 10:55 AM
ecorona6's Avatar
ecorona6
On a non-bose the tweeter uses the same connection as the door speaker, but seperates inside the door panel. The tweeter uses a small crossover circuit to remove the bass. There will be no seperate tweeter speaker line into the headunit.
Old May 30, 2006 | 11:16 AM
350ztoronto
yea thats what im going through right now i used both the speaker line and the tweeter line that splits and i couldnt' get any sound to my new tweeters damn this bose system
Old May 30, 2006 | 11:20 AM
Ichigo's Avatar
Ichigo
Do you have a wiring kit? If your not using one now I would recomend you acquire one (unless you have already murdered your stock wiring harness). Using the wiring harness inteded for the vehicle, it will give you all the right wire colors, purple, green, grey and white for the speakers.
Old May 30, 2006 | 11:21 AM
350ztoronto
yea i do and i wired them all together i've just about done everything can to get these tweeters to work with the stock wiring
Old May 30, 2006 | 11:24 AM
Ichigo's Avatar
Ichigo
And the door speaker on that side of the car works OK?
Old May 30, 2006 | 11:26 AM
350ztoronto
yea the speakers work but i ran new 16 gauge wire to them
Old May 30, 2006 | 11:37 AM
Ichigo's Avatar
Ichigo
If you ran new wire to the door speakers than your tweeters should still work if you did not disconnect the stock tweeter wires. Pull the door panel off to verify they are still connected all the way to the door gromet.
Old May 30, 2006 | 11:39 AM
350ztoronto
k will do brb
Old May 30, 2006 | 11:44 AM
03zsmith25's Avatar
03zsmith25
if you are trying to just splice in and keep the stock tweeter this will not work. you have to cut the stockers and use the same wire they were using or jsut run the tweets of an external amp. same with any system w/inline crossovers not just blose
Old May 30, 2006 | 12:17 PM
ecorona6's Avatar
ecorona6
This is your problem...you need to splice (like the user above mentioned) the new 16 gauge wire and tap into the small tweeter harness inside your door panels. Otherwise you are just suppling power to the door speaker and not the tweeter.
Old May 30, 2006 | 12:58 PM
350ztoronto
fawq, ok then but if i amp the one line to the door and then put it into the the input tweeter in the crossover will it be too much power for the tweeters?
well what i orginally wanted to do is use my amp to power 4 of my speakers and the tweeters would be powered by the headunit
Old May 30, 2006 | 01:18 PM
ecorona6's Avatar
ecorona6
All you needed to do is disconnect the door speakers leaving the tweeters connected and running a wire from the amp to the door speakers, thus powering the bigger speakers with the amp and allowing the headunit to power the tweeters.. This will probably not work if using a stock HU since you will need the speaker wires to connect an rca plug, but will def work if using an aftermarket HU.
Old Nov 9, 2024 | 08:04 AM
jg021v's Avatar
jg021v
Infinity Tweeters 375tx
File Type: html
Old Nov 9, 2024 | 11:55 AM
travlee's Avatar
travlee
Master
18.5 year dead thread
Old Dec 25, 2024 | 03:17 PM
amkkeolsa's Avatar
amkkeolsa
It sounds like you’re running into a wiring mismatch with the tweeter input. Stock tweeters often have built-in crossovers or rely on the factory system’s crossover setup to filter high frequencies, so connecting them directly to a head unit might bypass this. If the factory harness isn’t giving you a signal, double-check the wiring diagram for your car to ensure you’re connecting the correct wires. It might also help to test the continuity of the stock wires to confirm they’re not damaged.
