OPTIMA Yellow Top D51R discontinued...which model now?
Old Jun 14, 2006 | 11:52 AM
Tantrum Z33's Avatar
Tantrum Z33
Default OPTIMA Yellow Top D51R discontinued...which model now?
My battery is too weak for all the electronics in my car. I'm looking at the Optima yellow top and found out that the majority of guys went with the D51R. But, I just called every local dealer to find out that it has been discontinued. So I was wondering what model Optima battery are you guys using now that is lighter than our stock one?
I called Optima and they told me the D35 yellow top would be the right application for the Z. However, it's heavier than the stock one. So now I'm looking for a dry cell battery that will fit without any modifications to the cables and the bracket. Any suggestions?
Old Jun 14, 2006 | 12:00 PM
chimmike's Avatar
chimmike
not quite sure what this has to do with forced induction.
try posting in the correct section?
Old Jun 14, 2006 | 12:38 PM
z350phille's Avatar
z350phille
just go for the new and improved yellow one, or do as ia did get a red one.. works very well.
i got 2 yellow ones in the back
Old Jun 14, 2006 | 04:51 PM
gt3's Avatar
gt3
Would like to know as well...
Old Jun 14, 2006 | 07:46 PM
drsifu's Avatar
drsifu
D35.
http://www.1st-optima-batteries.com/index.html
10 lbs heavier than the D51R, but better CCA.
Terminals are on the correct side. My negative battery post is slightly smaller than the cable, so I may need to buy a shim, but other than that fitment is great. You'll need to use the supplied base since this battery is slighty shorter in height than stock one. It's also slightly smaller in width, but the OEM battery tie down will work.
Great service, price and quick shipment from the above website. Don't know if they have anymore.
Red top are also good as well, the only main difference between yellow top and red top is that the yellow one is deep cycle, which means it can be completely drained and than fully charged back up without problems. This is good for those who like to listen to music with the car off.
Red top acts kinda like a regular battery in that in loses some of its charging capability if you continually drain it.
Old Jun 14, 2006 | 08:04 PM
gt3's Avatar
gt3
Originally Posted by drsifu
D35.
Thanks for the info. So the D35 looks like the one to get.
Old Jun 15, 2006 | 07:39 AM
Realrammstein's Avatar
Realrammstein
Aren't the yellow tops sold at Costco, as well?
Old Jun 18, 2006 | 06:46 AM
Tantrum Z33
Thanks guys. I just went ahead and ordered the Yellow top D35. I was hoping to find a lighter dry cell battery but everyone I spoke to couldn't recommend one that will fit in the Z with none or minor modifications.
Old Jun 1, 2007 | 11:20 AM
VO...'s Avatar
VO...
Administrator
D35.
Good info. This is what I was looking for.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
