Help Wiring a Pioneer Headunit
Old Jun 22, 2006 | 07:58 PM
B-Unit's Avatar
B-Unit
Exclamation Help Wiring a Pioneer Headunit
Hey everyone. im a noob hehe and i need help installing my pioneer deh-p960mp head unit. Right now im looking @ the wiring diagram and im having a hard time understanding what connects to what..
Im keeping the stock speakers and everything. all im doing is connecting a head unit sooo heres some of my problems...
1. right now im looking at this speaker wires and the ones the plugged into the factory unit and i cant find similarities between the wires. the only wire that connects up straight with the colors that i can see is the yellow one... does anyone know what connects to what..
2. i have a white & white/black, a gray & gray/black, a green & and green/black and a violet & and violet/black to connect. which ones do these connect into from the stock ones..
Thanx
-B-
Old Jun 22, 2006 | 08:02 PM
B-Unit's Avatar
B-Unit
i think this will help..
https://my350z.com/forum/audio-and-video/171725-wiring-color-code-guide-for-350z.html
ill coem back if i have some more Qs after i give it a look.
thanx
-B-
Old Jun 22, 2006 | 08:09 PM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
Do you have a Bose?
Old Jun 22, 2006 | 08:10 PM
B-Unit's Avatar
B-Unit
ok need some help. im having a hard time understanding this literature...
LF Speaker +/- blue/red - black/white +,- radio harness
RF Speaker +/- yellow/red - red/white +,- radio harness
LR Speaker +/- lt. green/red - black/yellow +,- radio harness
RR Speaker +/- blue/orange - black/pink +,- radio harness
what is positive and negative...is this saying
LF Speaker... blue/red = negative, black/white = positive.......
Old Jun 22, 2006 | 08:11 PM
B-Unit's Avatar
B-Unit
Originally Posted by charlie_rdstr_Z
Do you have a Bose?
no no bose...
Old Jun 22, 2006 | 08:14 PM
B-Unit's Avatar
B-Unit
o i think i understand it now.
it should be spaced like this right...
LF Speaker +/- ......... blue/red -..... black/white +.........radio harness
RF Speaker +/- ......... yellow/red -.... red/white + ........ radio harness
Old Jun 22, 2006 | 08:15 PM
charlie_rdstr_Z
It should be all color coordinated. I hope you bought a wire harness so you don't cut any stock wire... Hope it's not too late.
Old Jun 22, 2006 | 08:16 PM
B-Unit's Avatar
B-Unit
well one came with the headunit... i was just going to splice in... isnt that ok?
-B-
Old Jun 22, 2006 | 08:17 PM
charlie_rdstr_Z
I'm talking about the harness that connects to the stock stereos harness. This way if you want to go back to stock you don't need to rewire it and it will be nice and clean. You can pick it up at a stereo shop or frys for about 10-15 bucks.
Old Jun 22, 2006 | 08:20 PM
B-Unit's Avatar
B-Unit
awwww booo. plicing in wont be too hard to fix tho.... im too impatient! i want to finish this tonight!
-B-
Old Jun 22, 2006 | 08:21 PM
charlie_rdstr_Z
I'm not sure but Bestbuy or Circuit city might still be open.
Old Jun 22, 2006 | 08:27 PM
B-Unit's Avatar
B-Unit
bleh. ill just go and pick it up tomorrow. once i get it should only be about 10 mins to wire everything up..
Heres what i got. the color on the left is the pioneer..
i got all this from using this...
does it follow???..... i think it does but i could be backwards?,,,,
Front Speaker Left
+ White ------------- Black/white
- White/black -------- Blue/red
Front Speaker Right
+ Gray ------------- red/white
- Gray/black ------- yellow/red
Rearr Speaker Left
+ Green ----------------- black/yellow
- Green/black --------------- Lt.Green/ red
Rear Speaker Right
+ Violet ----------------- black/pink
- Violet/black ------------ blue/orange
Old Jun 22, 2006 | 08:45 PM
B-Unit's Avatar
B-Unit
allright. i still have 1 more wires..
heres the pioneer description..
orange/white - (to lighting switch terminal)
-I was thinkin about connecting this ^^ to the radio illumination red/blue wire...
am i cool??? thanx guys
-B-
Old Jun 22, 2006 | 09:04 PM
charlie_rdstr_Z
Yes. They forgot to connect this at my stereo shop and I was blinded at night.
Old Jun 22, 2006 | 09:11 PM
Ichigo's Avatar
Ichigo
If you make the connection right you dont NEED the harness. It does save some work when and if you need to return the oem headunit into the system. Dont be a butcher on those wires though.
Old Jun 23, 2006 | 01:44 PM
B-Unit's Avatar
B-Unit
hey guys got a question,,,,,
i went and got a wirig harness this morning and im almost done with it but i have a quck Q.
on the harness pioneer gave me, theres a ground wire. and on the harness i bought to plug into the oem harness theres a ground.. can i just cut off the ground clamp and wire them together??.....
thanx
-B-
Old Jun 23, 2006 | 01:48 PM
B-Unit's Avatar
B-Unit
ima assume its allright and the right move. since the factory headunit obviously needs a ground. so its just transfering the power to this cord.
-B-
Old Jun 23, 2006 | 01:50 PM
Ichigo's Avatar
Ichigo
Yes you can use that ground wire. Or you can make your own by attaching it to a bolt or nut attached to metal in the console. Doesnt matter either way. But if you are going to "make" your own ground make sure the ground is attached directly to metal, not painted metal. If there is paint on your contact point it wont make a good ground. I always bust out the dremel and clean up my grounding points, paint or no paint.
Old Jun 23, 2006 | 03:03 PM
B-Unit's Avatar
B-Unit
sweet! i got the headunit working. now all thats left is the ipod unit..
i need a 12v source and a ground near the back end of the car..by the stock sub location...any recomendations?
-B-
Old Jun 23, 2006 | 03:31 PM
Voboy's Avatar
Voboy
-B-
splice another area of the 12v (yellow cord on the harness) and another area of the ground (black on the harness) and use an extension wire to bring it to the back? Since you have everything taken apart I assume, to stealth the ipod unit, then it shouldn't be too hard to stealth those wires as well.
