Need advice on choosing/configuring amp setup
Old Jun 23, 2006 | 05:23 PM
twotonicnite's Avatar
twotonicnite
Default Need advice on choosing/configuring amp setup
I currently have the following installed:
Alpine CDA-9835, MB Quart PSD 216s in front and Polk DB675 coaxials in the rear. I just purchased a JL stealthbox (deal I couldnt refuse) and I'm looking for some advice on amp(s). I listen to rock and jazz mostly and want good sound and some power but I dont really need or want window rattling bass. I bought the subs mainly because my current system has no bottom end whatsoever.
I'm considering the following:
1 JL 300/4 - 2 channels to the Quarts, other 2 bridged to the Stealthbox, and then just run the Polks off of my head unit since I keep them at low levels anyway. This method = small investment now with room to upgrade later.
What do u guys think?
Old Jun 24, 2006 | 07:33 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
That will work.
If you deside to go bigger you move the subwoofer of the four channel amplier and run it off it's own dedicated amplifier. If I were you I'd run three sets of RCA cables back to the location where you're mounting your four channel amplifier. I would also run the power cable back there a bit heavier too - enough to run a second amplifier.
The difference in parts cost isn't going to be that much more but you'll save the labor later on of having to run the cables when/if you ever up grade.
Old Jun 24, 2006 | 07:27 PM
maturola's Avatar
maturola
Default My Setup
Hey, this is what I recommend you and it is what I will have installed next week on my Z.
with the JL stealthbox - the JL 500/1 - Mono Class D Amp.
This baby will set you back for about $300 (look around).
the JL 300/4 will go the 4 Speaker
2 JL XR650-CSi (Component) in Front
2 JL XR650-CXi (Full-range) in the Back.
If you don't want to get 2 Amp, them run the speakers of the stereo and get the JL 500/1 for the stealthbox. Don't recommend using the 300/4 for the sub because you will be losing lot of power off those Subs . Don't go for the "e" series of JL either because they don't really distribute equal power and the it will start sounding weird
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
