Base Model Bose Hookup
Old Jul 20, 2006 | 04:14 PM
ssachetti's Avatar
ssachetti
Default Base Model Bose Hookup
Does anybody know if there is a hookup behind the speaker bracket for the 10' bose sub on nontouring models? Also, any suggestions for amps?
Thanks guys!
Old Jul 23, 2006 | 03:04 PM
ssachetti's Avatar
ssachetti
Maybe i should rephrase the question.
Does the base model Z require any additional wires to hook up the 10' bose speaker? Or does the sub plug directly in?
Old Jul 23, 2006 | 04:16 PM
wldkatz03's Avatar
wldkatz03
I'm pretty sure it'll need an amp and what not...if you're going to add a sub, i'd go aftermarket...the bose sub is not all that...in which case either way you'll need an amp to run the sub and a RCA converter that will wire into your stock head unit. Many guys have used Infinity's powered subs in the stock location or have had a custom box built to go there, that will sound the best! Good luck and check out some of the posts in the Audio portion...lots of great information!
350z82
Oct 1, 2015 06:25 PM
