stereo gurus please help amp question
Old Jul 21, 2006 | 07:44 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
Default stereo gurus please help amp question
all my equip is w/in a few months old and has worked perfectly until today. first let me state i just installed a engine ground kit last night. I dont believe this would do anything, but everything worked fine before. any way my component amp went into fault mode, any suggestions what to start checking first? like i said all eqiup is new and has been in perfect working order for the 4-5 months, and no changes except installing a engine ground kit last night?
Old Jul 22, 2006 | 01:43 AM
RockerNJ's Avatar
RockerNJ
1st step, disconnect the speakers/subs/whatever, power it on and see if it still goes into fault mode.
Old Jul 22, 2006 | 02:23 AM
ARMSTRONGARMS
and if i do and it doesnt? or if it does? im guessing if i unhook them and it doesnt go into fault i have a wire loose on speaker or grounded out. and if i unhook it and it still goes to fault the amp is crap'd out? correct
Old Jul 22, 2006 | 10:45 AM
RockerNJ's Avatar
RockerNJ
If you unhook the speakers and it still goes into fault, unplug the inputs next. If it still goes into fault with nothing more than +12v, gnd, and remote hooked up, you have a problem w/ the amp.
On the other hand, if you unplug the speakers, and the fault goes away, thats generally an impedance issue. Either you may have bad wiring, or possibly a melted voice coil, etc.
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Alexreyes
Sep 30, 2015 11:30 PM
