oem audio control
Old Jul 31, 2006 | 10:03 AM
raymondcleung's Avatar
raymondcleung
Default oem audio control
for the 2006 model, the steering wheel has audio controls for the OEM audio unit.
If I changed an aftermarket navigation system,
Will I still be able to use those audo control on the steering wheel???
Old Jul 31, 2006 | 10:08 AM
MeetJoeAsian's Avatar
MeetJoeAsian
that's a noper...there are very few systems out there that can hook up to an OEM controller...
Old Jul 31, 2006 | 10:15 AM
Blue_Z's Avatar
Blue_Z
what about the pac-swix?
http://www.autotoys.com/x/catalog/UN...WIX_p_597.html
Old Jul 31, 2006 | 10:28 AM
Ichigo's Avatar
Ichigo
There are adapters available. Most likely candidate is something from the PAC line of adapters. A few searches on this board will get you the exact model numbers folks here have used successfully in the past. It may involve soldering resistors to make it work with your Z but I would recomend sending it to a shop to have it done. If it doesnt work you have someone to blame besides yourself.
Old Jul 31, 2006 | 11:42 AM
usmanasif's Avatar
usmanasif
Yes, the SWI-X will let you do that.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
350z82
Oct 1, 2015 06:25 PM
