ECU and Nav unit
Old Aug 2, 2006 | 04:49 PM
Cannysage's Avatar
Cannysage
Default ECU and Nav unit
can you hook your ecu to an aftermarket nav system to display every parameter that a PC can?
Old Aug 3, 2006 | 05:15 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I don't have any ECU reader experence but if they require a PC to read them it is possible. What you'd have to do is to connect the PC to the ECU and take the normal VGA computer video output and run it into a converter to change it to composite video. That composite video signal is what the dash displays - DVD's and navigation units are creating. The output video of the computer will need to be matched to the input of the monitor - try starting with 640 x 480 resolution. Many monitors and converters will do better than that but that's a safe place to start.
Old Aug 3, 2006 | 06:36 PM
702Fairlady's Avatar
702Fairlady
I think he was asking if he can hook up the ECU directly to the dvd/nav instead of actually having to use a PC. No idea. I know a good bit about car audio, but I've never seen it done. What parameters are you trying to read out? A/F Ratio and stuff like that?
May 30, 2017 03:28 PM
dcains
Nov 11, 2015 11:36 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
