Sirius satellite aftermarket installation on '03 Bose sounds system?
Old Aug 10, 2006 | 04:59 PM
Pepperhead's Avatar
Pepperhead
Default Sirius satellite aftermarket installation on '03 Bose sounds system?
Is that feasible without having to change the headunit? Can I install Sirius Satellite on my '03 Bose headunit without having to change anything? Thanks in advance for any input.
Aris
Old Aug 10, 2006 | 05:52 PM
kpiskin's Avatar
kpiskin
The factory headunit in the 03s did not accomodate satellite radio. Only 04 and above models do. Also it is not a simple plug and play thing since they both use different harnesses. I'm not aware of an adapter.
Old Aug 10, 2006 | 06:00 PM
Pepperhead's Avatar
Pepperhead
I guess this means that I shoudl forget about it?
Old Aug 10, 2006 | 06:02 PM
Ichigo's Avatar
Ichigo
You can get a plug and play unit, but there is a matter of where to mount one in a Z. I would go for a new headunit that is Sat ready, you wont believe the difference getting rid of the stock head can make.
Old Aug 10, 2006 | 06:05 PM
Pepperhead's Avatar
Pepperhead
No doubt about that, but are you aware of any HUs that much the interior and fit the opening as perfectly as the OEM one?
Old Aug 10, 2006 | 06:06 PM
Ichigo's Avatar
Ichigo
If you insist on keeping that head unit, your only option is a plug and play unit. And there's not alot of dash space to mount one. You might be able to do a sirius visor unit without alot of hassle.
Old Aug 10, 2006 | 06:08 PM
Ichigo's Avatar
Ichigo
with a decent mounting kit all the single DIN headunits look really nice. If you want to maintain a factory look, get one with an amber display.
Old Aug 10, 2006 | 06:12 PM
Pepperhead's Avatar
Pepperhead
Thanks for all the useful information! Do you happen to know of any decent HUs with amber illumination?
And regarding the 1st option (keeping the stock HU), how much is the cost and where can I get the hardware from? TIA buddy!
Old Aug 10, 2006 | 07:41 PM
Ichigo's Avatar
Ichigo
After checking out some head units, I've noticed you have to move up in the product lines pretty far to get variable color displays, and most of the entry level units start around $100 and have blue displays. To get to the units that have variable colors you into a $200.00+ deck. Then add a Sat tuner for about $80-$90. A mounting kit for $16.00, wiring kit for $12. Then toss in an install for about $100.00 and your jamin.
OR
A sirius Visor unit, very cheap, very easy to install and very compact. $50.00 for the unit and its single line display makes it very easy to clip to your visor and run power, ant wire and I would recomend a hard wire tap into your existing factory antenna. Wireless transmission of sat signal to a headunit sux. Wired antenna adapters (can be had for $25-50) are the way to go if you dont have an auxport on tha back of an oem headunit. All in all three wires running up to the visor.
Both will give you sirius, the visor is cheaper, but if you have the funds I highly recomend replacing the headunit in favor of an aftermarket deck. It's easier to read and easier to control your sounds from one source, instead of two.
Check ou the offerings from Kenwood, Pioneer, Panasonic, and Alpine. All offer great choices for headunits that are sat ready and compatable with XM and sirius.
Old Aug 12, 2006 | 01:13 AM
Pepperhead's Avatar
Pepperhead
Thanks a ton man! I'll look into it, although I'll go with the 2nd option most likely (I'm not keeping the car for a long time so I don't wanna throw much $$ on it). I'll let you know how it goes.
Old Sep 11, 2006 | 12:44 PM
geomark's Avatar
geomark
How'd it go with the install? I am thinking of adding Sirius to a factory 05 with Bose. I don't know if the back of the unit has any plugins. Anyone know?
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
SharX59
Sep 27, 2015 09:23 AM
