Audio Question
Old Aug 11, 2006 | 12:14 PM
UofA350Z's Avatar
UofA350Z
Question Audio Question
Lately, my right front speaker has been fading in and out. It never goes all the way out, but it gets a lot softer than the driver's side. It usually only does it if I have a CD playing, never on the radio. And it's not certain songs either, it may do it on one song, and if I replay that song it'll be fine. And That's only part of the problem...last time I tried taking the door panel off to get some FATMAT in there, one of the screws was stripped and just spinning so I could never get the panel off, so I can't really get behind the speaker to check the connection. Any ideas what might cause it to get a lot softer than the other one...and how I can get my door panel off? Thanks in advance.
Old Aug 11, 2006 | 12:23 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Normally a loose connection gets the speaker to cut in and out rather than fading the volume. Problems with the head-end or amplifer are more likely to cause problems with fading.
Old Aug 26, 2006 | 03:29 PM
UofA350Z's Avatar
UofA350Z
I noticed today that the problem only occurs when CDs play. If the radio is on, all 4 speakers work fine. If I switch to a CD, the speakers may work fine for a little while, but then the speaker in the passenger door gets real soft, and when I switch the Fader all the way to the right side the speaker sounds real bad...but it doesn't do that on the radio. Any ideas?
Old Aug 26, 2006 | 04:29 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Originally Posted by UofA350Z
Any ideas?
You've pretty much confirmed it's internal to the CD unit and requires bench work.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
