Valentine1 direct-wire install
Old Mar 1, 2003 | 09:37 AM
FastEddie73's Avatar
FastEddie73
Question Valentine1 direct-wire install
Has anyone attempted to install their Valentine1 radar/laser dectector using the direct-wire adapter that comes with it? The instructions say to crimp it to one of the of 12 volt "switched" wires, but I'm leary of doing this.
Has anyone done this with theirs? Which wire did you use? Or did you plug it into the fuse box instead?
Old Mar 1, 2003 | 09:53 AM
STLZ's Avatar
STLZ
I did a direct wire to the red wire with a brown stripe on it. It is a power wire so when the car is turned on the detector goes on. Turn it off and it goes off. Hope this helps
Old Mar 1, 2003 | 10:42 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
If you do a search on Valentine One install you'll see several threads that can walk you through it with pictures.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
