non bose / bose head units interchangable?
Old Aug 19, 2006 | 06:32 PM
Cozmo's Avatar
Cozmo
Default non bose / bose head units interchangable?
anyone know if if I have a non bose headunit, can i put in the bose one or will that not work? anywhere i can look this info up? thanks
Old Aug 20, 2006 | 12:26 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Not a direct swap.
I don't have a base system but the Bose system has lots of extra "moving" parts that the base doesn't have and I doubt that Nissan goes though the expense of wiring all cars for the Bose system. You can check yourself by looking under the plastic foam structure under the antenna in the left rear of the trunk. You ought to find a connector for the four channel amplifier. There would be another one behind the driver's seat where the Bose sub-woofer amplifier and speaker would go.
Up front you'll find extra jacks behind the head-end for the microphone and extra line level outputs that run off to the amplifiers and then back to the speaker mounting locations.
Pleask
Dec 21, 2021 03:17 PM
May 30, 2017 03:28 PM
dcains
Nov 11, 2015 11:36 PM
