Radar detectors in Zs
Old Sep 15, 2006 | 04:45 PM
MIKE3348's Avatar
MIKE3348
Originally Posted by leemik
lol maybe you should learn about all different Z's first before flaming somebody All 04's and up all have a cig lighter socket next to the passenger cup holder.. only 03's are missing this feature..
Search "Mike Peronek" for the Z mount..
--mike
Zmazing03,
I make the mirror mounts for the Bel detectors. PM me for details. I have the mounts in stock.
Mike Peronek
Old Sep 21, 2006 | 01:39 AM
flynbrin's Avatar
flynbrin
guys i have a valentine 1
i just want to stretch my cord
but how should i do it?
thanks
Old Sep 21, 2006 | 04:10 AM
perrogrande007's Avatar
perrogrande007
woo hoo! I just bought the Passport SRX and am about to install it....right now! Wish me luck!
Old Sep 21, 2006 | 04:13 AM
_Donovan_'s Avatar
_Donovan_
Any truck stop in America usually has a 3 ft. extendor for the A\C plug. I believe it is $10.
Old Sep 21, 2006 | 05:20 AM
RBlover69's Avatar
RBlover69
Yeah, see, maybe you should learn about all different Z's first. Only the 06's have that, while the previous years did not.
i have a 04 and i have 2 cig outlets one near the pass and one behind ???
Old Sep 21, 2006 | 07:10 AM
ANXIOUZ's Avatar
ANXIOUZ
thanks
Grab one end, have a buddy grab the other, walk in opposite directions.
Old Sep 21, 2006 | 09:14 AM
maturola's Avatar
maturola
even tho this is true!.,,, sound funny!
Old Sep 21, 2006 | 09:32 AM
SunburstZ's Avatar
SunburstZ
Just bought a V1, the invisicord, and the mirror Z mount... waiting to be mounted!
Old Sep 21, 2006 | 10:05 AM
Skimaster1589's Avatar
Skimaster1589
Gotta love the Valentine 1 its so good i plan to have a custom install eventually when i have the money
Old Sep 21, 2006 | 10:17 AM
Ichigo's Avatar
Ichigo
Great information fella's! I just bought my Escort 8500 X50. Got me the mount and invisicord on the way. Perfect timing.
Old Sep 22, 2006 | 06:26 PM
islandsnow's Avatar
islandsnow
Just mounted my bel rx65, mirror bracket and invisicord. The only problem is the bel bracket is a little flimsy when it locks into the detector. It doesn't lock solidly, it's slight but does have movement and with it mounted on the bracket it's too short. The buttons are just underneath the mirror, so you have to bend it down or take it off to adjust it or turn it off. I like mine pointing even and it looks like the mirror is blocking the rear laser pickup at level. I will test it tomorrow with my golf laser distance binocs and see if the rear is still protected. Other than that, it looks great up there.
Old Sep 22, 2006 | 06:41 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
You do know that you can adjust the mirror up and down right not just swivel up and down? Therefore, you can make the mirror-holder (attached to mirror and windshield) move. You then have to unbend the metal piece that locks the detector in place to level the detector.
I have the Bel RX65 Pro and mine clears the mirror just fine. In fact, there's quite a bit of room between mirror and detector.
Old Sep 22, 2006 | 09:02 PM
CG 350Z's Avatar
CG 350Z
Although the bracket is pretty good. I don't know I just seem to like the V1 that is placed right into the mirror. It conceals the unit 100% comletely out of front windshield view and IMHO looks better. Speaking of which, does anyone know who sells those V1 mirrors?
Old Sep 22, 2006 | 09:35 PM
islandsnow's Avatar
islandsnow
I didn't inspect the mirror mount, thought it just swivels, didn't know it extends. Mounted the bracket as far down as could and then bent the bel bracket to make it level. My detector is practically touching the bottom of the mirror, I like the way it looks that way since it's not hanging down too much, but i'll check tomorrow and extend the mirror a little. Thanks, for the info.
Old Sep 22, 2006 | 09:37 PM
3hree5ive0ero
Retired Admin
It's not so much as "extending" as just repositioning. Most mirrors do more than just swivel around - they can go up, down, left, right.
Old Sep 22, 2006 | 10:01 PM
islandsnow's Avatar
islandsnow
you can check with this guy, he installed his V1 remote display in the mirror.
http://www.piddles.net/V1-Install.htm
Old Sep 23, 2006 | 10:20 AM
islandsnow's Avatar
islandsnow
Just readjusted the mirror, you're right there are 2 swivels, one on the mirror side and one on the windshield side. I was able to get about a 1/4 inch more clearance so all is fine. Working great now. The short invisicord is perfect, just plug it right into the back of the mirror connector and tie wrap.
Old Sep 24, 2006 | 02:41 PM
  #38
3hree5ive0ero
Retired Admin
Glad it all worked out for you.
pinkie
Sep 16, 2022 09:55 AM
lazyZ
Nov 9, 2006 07:24 AM
flsunset
May 12, 2004 04:39 PM
Bonner928
Nov 12, 2002 06:08 AM
Samurai
Sep 23, 2002 06:32 AM
