View Poll Results: Choices
Zapco AG750
21.43%
PPI PCX-2200
14.29%
JL 10 W3v2
42.86%
JL 10W6
50.00%
Multiple Choice Poll. Voters: 14. You may not vote on this poll
Vote on the system choice....
man, thanks again...
I really want to compare the Diamond Audio Amps, but i can find a price online. Can you buy them online???
BTW, its looking to be b/w
Orion HCCA 250G5
Orion XTRPRO 1000 (but i was under the impression that w/ Orion, HCCA was the way to go?)
PPI PCX-1500
Cant find the Zapco or Diamond Audio prices (important criteria)
Just an Update..
Orion HCCA 250G5
PPI PCX-1500
Just an Update..
if your around right now you HAVE TO check this out, this a great deal for the PPI mono block amp! it has a retail list price of $799. the listing ends in 45 mins and at only $439! this would be a perfect match for 3 D4's! it would drive them with 330 each at day long! this one has it all!!!! hope your around to check it out
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3011349945
daaaaaaaaaammnnnnnnnnnn itttttt!!!!!!!!!!!!!!!!
misssed it....
thanks though, good lookin out.
real quick, i like the Orion HCCA 250G5 & the PPI PCX 1500, the reason im leaning on the HCCA is because of $$$, trying to keep it as much as budget as possible (so $$ can go into other Z parts
). That PPI is the shi (especially @ that $$$), but how good is the HCCA in comparison (not watt wise, but quality....)
thanks
misssed it....
). That PPI is the shi (especially @ that $$$), but how good is the HCCA in comparison (not watt wise, but quality....)thanks
hey he listed it again!!!!
http://cgi.ebay.com/ws/eBayISAPI.dll...category=18797
There is no doubt that I would grab one! Like I said before, this amp is bad ***! Esp. at nearly 50% off retail lost!
As for this VS that Orion...would do the PPI for sure! There is no bridging so its not running near as hard as the Orion would! You would be bridging the 250G4 all the way down to 1ohm mono when its a 4ohm stereo amp. The amp well be running alot harder than the PPI!! Which means more heat and a hell of a lot more power drain on the car b/c its not regulated amp and will perform based on voltage levels! The PPI's board is fully pulse regulated!! If your giving it 10.5 or 14.4 its going to give you the same output regardless of power peeks and drops unlike the 250G4 will be dependant on them! It will be 333 per sub (which is right in the JL rated "optium" power range) where as the Orion will be 266 (which is below). At $439 there is no way personally would pass this up or even look another further!
$.02
$.02
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
